225/75/15 VS 31x10.50r15
Old 11-01-2009, 01:04 PM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Do the gears now, that way if you decide to go to a larger tire later, you wouldn't be buying the tires and the gears at the same time, then.
Old 11-01-2009, 02:23 PM
Built2Grind's Avatar
31" from the factory ran 4.30 gears(right?), so a 225 tire with 4.88's would suck on the freeway, im gonna run the stock tire size when i get new tires i a month or so, the tires im running now have about 1/8" of tread left so its time for tires anyway.
Old 11-01-2009, 03:02 PM
limon32's Avatar
Based on what you want to do with the truck, I'd go with 31x10.50s. You will have much better tire selection (for trail tires), I doubt you will notice much of a performance change (as others posted above).
I just swapped from my 33x12.50 summer tires to my 245/75 winter tires and barely notice the difference.
mldave
09-21-2015 08:21 AM
ricoace
07-28-2011 02:39 PM
Kyle95sr5
12-18-2006 03:00 PM
Nic
10
06-27-2004 04:39 PM
Quick Reply: 225/75/15 VS 31x10.50r15
