2 inch body lift?
Old 11-26-2006, 04:36 PM
95_4MuddinSr5's Avatar
2 inch body lift?
I have an automatic 95 4runner with a stick for 4wd(ifthat helps). Can I buy Performance Accessories body lift for my truck but for a manual and buy a automatic transmission drop bracket thingy from 4crawler.??????????? and what else do i need?? WHat do you suggest i do???? Thanks a bunch!
Old 11-26-2006, 04:39 PM
slosurfer's Avatar
I would talk to 4crawler and just get it all from him or Wabbit
Old 11-26-2006, 05:58 PM
suprathepeg's Avatar
Or make it yourself. UHMW poly rods are cheepm, all you have to do is cut to length and drill for bolts.
Old 11-26-2006, 08:02 PM
91ToyTrck's Avatar
I personally would talk to 4crawler and buy everything from him.
Old 11-27-2006, 03:16 AM
mt_goat's Avatar
X2, are you sure you need 2 inches of BL? A little BL goes a long way. I sometimes think my 1" is a little too much. How did you get a stick on the auto transfer case, is it a 3.4?
Old 11-27-2006, 08:15 AM
anthony1's Avatar
If you do a 1"BL,then you don't need to extend any of that stuff. You can fit 33 with some banging of the inner fender..
Old 11-29-2006, 04:42 PM
Hey goat i did'nt know if it mattered or not to mention what type of 4x4 selecter i have so i just included it. it sits right next to my automatic trans selector but it does not look like the ones in the manuals like my friends toyota. I'm thinkin 1-1.5 is a better decision now after all the comments thanks. 4Crawler all the way.
Old 12-06-2008, 05:27 PM
afnf_life's Avatar
where could i get a 1 inch body lift for my 93 4runner??
Old 12-06-2008, 05:30 PM
85TurboRunner's Avatar
Some peoples kids. Didn't you read the post, 4Crawler or Wab Fab for a body lift.
Old 12-06-2008, 05:36 PM
toyNG's Avatar
I would suggest going with the 1", unless you absolutely need the 2".
The 2" requires quite some extra work besides just inserting the blocks. I had to extend my steering shaft, drop the fan, adjust the front bumper, mess with both shifters, and probably some other stuff that I can't remember. Most of this is not needed if you are doing a 1".
The total process took me about half a day, but 90% of it was adjusting all those other things I just mentioned. A 1" would have probably only taken an hour or two.
And I would also recommend going through 4crawler for everything.
Old 12-06-2008, 05:38 PM
afnf_life's Avatar
where could i get 1 inch body lift for my 93 4runner automatc
Old 12-06-2008, 05:39 PM
afnf_life's Avatar
sorry bro i looked at the wabtech website and didnt see anything
Old 12-06-2008, 05:40 PM
afnf_life's Avatar
i mean wab fab
Old 12-06-2008, 05:41 PM
abecedarian's Avatar
http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml
read the page.
Old 12-07-2008, 01:32 AM
JamesD's Avatar
When I did my 3" on my 89 auto, I had to use the drop bracket for the transmission shifter and I had to lengthen my transfer case lever rod. On the 2" I would assume you would have to do the same.
James
Flying91
45
04-11-2024 04:39 PM
09-04-2015 09:27 AM
Michael oaks
07-27-2015 11:47 AM
Steven.m.paulk
07-24-2015 01:44 PM
Cabell
07-24-2015 12:14 PM
Quick Reply: 2 inch body lift?
