1995 22re... coolant in oil.
Old 04-08-2008, 10:49 PM
Squeebs's Avatar
My buddy has a 2wd pup with the 4 banger... he has coolant in his oil and is convinced that it is his head gasket... im not.
it starts up, runs like a parapalegic... But no white smoke from under the hood.
Any other ways these engines have been known to let coolant into the oil?
Old 04-08-2008, 10:54 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
The timing chain can wear through the timing cover on the driver's side. Behind that area of the cover is a coolant passage coming from the water pump. So, yeah....in this case no coolant would entering the combustion chambers....just damaging the bearings.
Old 04-09-2008, 07:22 AM
eric-the-red's Avatar
I would confirm the headgasket theory with compression and leakdown tests before tearing into the engine.
Old 04-09-2008, 07:47 AM
CJM
CJM's Avatar
Coolant in oil means the HG. Period..
Old 04-09-2008, 08:45 AM
thook's Avatar
No.....it doesn't. On a V6....certainly. But, the 22re can be just the timing cover.
Old 04-09-2008, 12:06 PM
Slowstrike's Avatar
22re coolant in oil = timing chain rub thru. My bet is that when you open it up the driver side guide is eaten through or fell into the oilpan.
Longbed 90
03-11-2019 12:38 PM
JUICE222
10-13-2015 08:50 AM
viesail
09-21-2015 06:00 AM
Boomer8404
09-20-2015 06:15 PM
LotOMiles
09-14-2015 11:45 PM
Quick Reply: 1995 22re... coolant in oil.
