1993 Toyota 22RE ticking after valve adjustment
Old 05-10-2015, 01:01 PM
Lzryde's Avatar
Just bought this truck a few months ago and this weekend I decided to check the valve adjustment.
The truck sounded great before, at least at idle, considering the exhaust is loosely attached to the header and there's a .50cal size hole in the muffler lol!
I followed the FSM http://www.eagleoneresearch.com/manual/ToyotaMaual.pdf
Page 32
I'm positive I was on the proper stroke while doing the adjustment!
I even rotated the engine 4-5 times double checking the clearance after adjustment on both sets of valves on both strokes. I also made an effort to keep the feeler gauge flush with the valve stem/rocker while adjusting
Before the adjustment I could not even get the proper size feeler gauge between rocker and valve stem. I wouldn't be surprised if PO just made them 'tight'
Should I be worried about the valve noise? Is 'too loose' better than 'too tight'?
Thanks!
Lzryde
Old 05-10-2015, 01:16 PM
millball's Avatar
Loose is better than tight.
One mans 'ticking' is anothers 'just right'.
I don't know why everybody wants their 22re to run completely silently.
Properly adjusted solid lifter engines seldom do.
Old 05-10-2015, 01:17 PM
Lzryde's Avatar
Yeah I've heard that these motors are supposed to sound like sewing machines and that's how they like it! Thanks for the reply!
Old 05-10-2015, 01:30 PM
wyoming9's Avatar
Red face
Then you might have over tightened the valve cover bolts that makes a tapping noise when you do.
No lifters that is a hard habit to break no push rods either
Old 05-10-2015, 01:33 PM
millball's Avatar
Yes, no lifters or pushrods, but still solid-- no hydraulic lash control.
I guess I should have said solid valve train instead.
Yont283
09-23-2022 08:06 PM
Weidle
01-21-2019 05:39 AM
Gamble_STi
07-01-2015 12:51 PM
Gamble_STi
06-27-2015 07:54 PM
nyk08trx
06-18-2015 09:01 PM
Quick Reply: 1993 Toyota 22RE ticking after valve adjustment
