1993 4runner brush guard help
Old 11-01-2011, 07:42 PM
jbuck07's Avatar
ive looked everywhere on here to find an answer to my question but..... i am looking for a brush guard (not a whole new bumper) i want to keep the stock one. the only problem is i have a 3 inch body lift and if i were to install a brush guard, it would be 3 inches lower than what the body is at because it bolts to the frame; not the body.
anyways, do they make brackets for it to raise it up 3 inches, just like they do for the bumper when you put a body lift on? or are there any other options out there??
Old 11-01-2011, 08:48 PM
john4wd's Avatar
Take body lift off then put on brush guard and then install a suspension lift or you'll have to make your own brackets.
Old 11-01-2011, 08:58 PM
JamesD's Avatar
You will need to cut the brush guard and weld it 3 inches longer and no to your question.
James
Old 11-01-2011, 11:29 PM
wyoming9's Avatar
Smile
If you were unable to figure this out on your own
You will most likely need someone to make your brackets without seeing the brush guard in question in may just be easier to modify the brush guard by adding the length needed to make it work.
Although with cosmetic work to match all the paint or powder coating it could get expensive.
Old 11-22-2011, 03:36 PM
jbuck07's Avatar
Yeah, thanks alot for the help guys!
Charecter1
11-06-2023 10:08 AM
icentropy
09-16-2020 02:47 PM
XtraCab
04-12-2020 05:25 AM
Colington
03-08-2020 09:51 AM
colinmil
07-06-2015 04:03 PM
Quick Reply: 1993 4runner brush guard help
