1993 4runner 3.0 will crank but when you give it gas it bogs down and then back fires
Old 04-16-2011, 08:43 PM
4Runner73's Avatar
I Have a 1993 4 runner I just bought. I bought it not running. I replaced the fuel filter, fuel pump,(Last owner fried the fuel pump using a wire from battery to fuel pump) plugs cap and rotor. The truck isnt throwing a code and i don't know wha else to check. Converter is good also.. Thanks for any help!!!!!!!
Old 04-16-2011, 09:25 PM
totally a bro
Staff
vital22re's Avatar
check firing order and ignition timing
Old 04-16-2011, 09:26 PM
1gen4run's Avatar
Did you check the timing? Did the guy you bought it from give you any history?
Old 04-17-2011, 06:31 AM
4Runner73's Avatar
No history except it was a one owner and the timeing belt was replaced about 20thousand miles ago. It set up without running for about a year. He replaced the fuel pump but it would not run so he ran a hot wire to it to get it to crank but that burnt up the fuel pump. I replaced several fuses a 2 relays fuel filter and the fuel pump. Cranks rite up and idols fine but it loads up when u give it gas.
Old 04-17-2011, 07:07 PM
1gen4run's Avatar
Could even be a vacuum leak. Make sure all the lines are still connected. Just like a kid in a candy store, so many choices of things to try.
Old 04-17-2011, 07:18 PM
4Runner73's Avatar
I have checked the vacuume lines havent been able to find one leaking but who knows I am at a stand still, I don't know what else to do. Guess I will just have to put it in the shop.
justin_4runner's Avatar
test the afm or tps u can find the way to test them in the fsm and that can be found here... http://www.ncttora.com/fsm/index.html
Goddamnboh
3.4 Swaps
12
05-11-2016 09:22 PM
94 bikehauler
06-30-2015 11:19 PM
ZONAYODA
06-30-2015 05:36 PM
odonekanobe
06-26-2015 02:27 PM
yamaha73
06-18-2015 06:19 PM
Quick Reply: 1993 4runner 3.0 will crank but when you give it gas it bogs down and then back fires
