1989 Engine Knock
Old 10-03-2009, 08:22 PM
1989RedToyota4Runner's Avatar
1989 Engine Knock
I have a 1989 V6 4 runner with a knock. It knocks when in idle, along with gear. When I speed up knocking gets faster/louder. When I push clutch knocking goes away. Any ideas about what the problem could be and how to fix this. Please help me. I am 17 and it is my father's truck. He will be back from baghdad in 1 1/2 months, so need to fix before then.
Old 10-03-2009, 09:30 PM
myyota's Avatar
You said it stops when you push the clutch in, so it could be a bad clutch or possibly a loose flywheel. You will need to pull the transmission to figure out what the problem is.
Old 10-04-2009, 06:11 AM
It sounds almost like a radeling. Like if you have a golf ball inside a blender.
Old 10-04-2009, 06:34 AM
22RUCRAZY's Avatar
have someone push and release the clutch while you r under the truck listening . With e brake on Look at all external components of the clutch before you pull tranny . There is a boot on the tranny you can move to get a look at the inner workings . Does your pops know that your driving his truck does he know its broken you should tell him before you fix it
Good luck and keep us informed
Old 10-04-2009, 06:51 AM
yeah he knows I'm driving it and it has always been "broken" in some way. No e Brake, 4wd locked up, pops out of 1st, rear window won't go down, leaks oil, radio is shot, a few other things. As far as this kinda broken no. Our neighbor is a mechanic I am going to try to get him to look at it today. I am only at auto tech as old red (truck name) will teach me. Ever time something breaks I usually learn how to fix it so this is a fix time for me with this kinda problem.
icentropy
09-16-2020 02:47 PM
RaginAsian91
Engine Swaps
03-30-2019 09:17 AM
mskalmus
05-28-2017 07:51 AM
smiley52
07-11-2015 05:16 AM
Quick Reply: 1989 Engine Knock
