1988 V6 Ex Cab 4x4 auto rear drive shaft..What other models fit it?! - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-14-2009, 12:30 PM   #1 (permalink)
Ilovemountains's Avatar
Question 1988 V6 Ex Cab 4x4 auto rear drive shaft..What other models fit it?!
When I swapped out my rear end I noticed that the U joint on my rear drive shaft on the transmission end is loose, I mean you can actually move it left and right and there is visible slop in the joint. Im noticing a lot of vibration and Im wondering if its all coming from a worn out drive shaft joint. Anyway, does anyone know what model trucks or runners drive shafts would fit my 88?? I'm assuming any V-6 x cab auto would fit but thought Id ask the experts before I try to find a new to me used drive shaft! Does anyone have one they would like to part ways with??? Can I just replace the joint on the shaft because the slip yoke and the rear joint seem OK?? Thanks again!
__________________
88 3.0 XCab, K&N fipk, Borla cat-back,Magna Flow Cat, Downey frame brace, Downey 2" rear springs, BJ spacers, Aisin manual hubs,B&G Fiberglass bed, extended diff. breathers, Bilstein HD shocks, Rancho RS5000 stabilizer, Brembos & TRD Pads, Revos, Hella 500s, 4 runner bucket seats and console ETC ETC...
Ilovemountains is offline
Old 05-16-2009, 03:35 PM   #2 (permalink)
Question Anyone?
No one knows what other years or models rear drive shafts fit my truck?? Im not having much luck finding one for an 88, would it be safe to say that 88-95 ex. cab V-6 Auto trucks used the same rear drive shafts????!!
__________________
Old 05-16-2009, 03:43 PM   #3 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
uh... doesn't matter much which shaft fits which at this point:
... slop in the joint means the joint needs replaced
__________________
Quote:
Originally Posted by Junkers88 View Post
I went and looked at that Ford.... I can't tell if the vehicle was just abused or if domestic builders don't see the point in building something that will last and look good.
I'm going outside to hug my 4runner.
Quote:
Originally Posted by DeathCougar View Post
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Old 05-17-2009, 06:39 AM   #4 (permalink)
Exclamation U-Joint replacement?
I didnt know you could replace just the joints, I thought you had to buy a whole new shaft, though I wonder if it is still cheaper or easier to just buy a used tight drive shaft, which is why Id like to know what models and years would fit my truck! How hard is it to replace the joint? It looks like the slop is not on the bearing side rather than the side with the holes that the bearings ride in look elongated, as far as I know when you buy a new U joint you just get the rebuild bearing side but I could be wrong! Im going to google it now.
__________________
Tags
4runner, cab, driveshaft, ext, fit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
xtended cab drive shaft rochelle 84-85 Trucks & 4Runners 8 12-08-2007 05:10 PM
WTB Xtra Cab One Piece Drive Shaft Flash319 The Classifieds GraveYard 5 08-26-2007 09:29 AM
How many grease nipples on rear drive shaft on 4x4 4runners? milowilli 95.5-2004 Tacomas & 96-2002 4Runners 6 04-10-2007 06:09 AM
Long box standard cab on the 1986-1988 models BCtoyota 95.5-2004 Tacomas & 96-2002 4Runners 3 04-12-2005 12:03 PM
2009 InternetBrands, Inc.
