1988 3.0 the same as 1994 3.0?
Old 10-24-2007, 05:40 PM
Sponsor
Tofer's Avatar
I may be able to get my hands on a 3.0 out of a 1988 4runner. is there a large difference between a 3.0 from 88 and 94?
Old 10-24-2007, 05:45 PM
881stGenRunner's Avatar
o ya, the 88-92 3.0s were essentiall the same and hte 93-95 3.0s were the same. you would be able to get it in, but there will be a lot less 'crap' in the engine bay. go for it. You also wont have any problems with the HG since the early 3.0s werent prone to failing.
they also had about 10 less hp
Old 10-24-2007, 05:48 PM
Sponsor
Tofer's Avatar
sweet. looking here http://www.top4runners.com/ja/runhist21994.html it appears the biggest difference is an auto tensioner on the timing belt
Old 10-24-2007, 05:50 PM
isaac338's Avatar
so your old motor is definitely toast i take it? (can't be bothered to look up that thread)
Old 10-24-2007, 05:53 PM
my bro has a 94 3.0 and i have an 88 3.0. ill try to get pics of the engine bays tomorrow for ya.
Old 10-24-2007, 05:59 PM
Emms4runner's Avatar
Ive come across a few differences when buying spares for my 90 model, but mine has a replacement engine so i don't know what year it is.
I know the knock sensor is different, and on the dizzy to there can be differences with the wiring loom that comes out of it.
Old 10-24-2007, 06:09 PM
Staff
DeathCougar's Avatar
Lots of incorrect info in this thread, so be careful what you get.
The 1988 V6 was a stand alone engine. The mounts on the block are drilled and tapped in a different place. My assumtion is that they didn't want to create new frame mounts for the new v6 motor, and just left the 22R mounts there. An 88 engine will NOT bolt into any year but and 88. The mount bosses are not even there to drill and tap to be able to install the engine. Major PITA. You CAN go from a 94 truck into an 88, but you have to drill and tap the mount bosses.
**4runner was sorta correct, the 89-92.5 long blocks are the same, as are the 92.6-95 long blocks. In 92.5, Toyota switched to the hydraulic style tensioner, which required an extra hole be drilled in the Pass side head. The tensioners, fan support, and fan assemlies are all different between 89-92.5, and 92.5-95.
So, to answer your question, NO you cannot use the engine from the 88 in your 94.
Old 10-24-2007, 07:27 PM
Sponsor
Tofer's Avatar
crap..... black to the drawing pad....
Old 10-24-2007, 07:30 PM
Thanks DeathCouger. You have the ultimate knowledge when it comes to 1st gens. i hope i get to where you are someday!
Old 10-24-2007, 08:10 PM
Mr_Martinez1982's Avatar
mmmm mines a 92 not the 92.6 an it had the HG failure, also had the recall. you sure about that?
Old 10-24-2007, 08:11 PM
Sponsor
Tofer's Avatar
i just got off the phone with a toyota master mechanic... he said that it will work. i figure even if for some reason it doesnt work i'll sell it on craigslist.
Old 10-24-2007, 08:58 PM
Staff
Lol ok, but dont say i didn't warn ya!
Old 10-25-2007, 05:04 AM
Sponsor
Tofer's Avatar
for the price i cant be wrong.... even if i can use parts outta it in the rebuild it'll be worth it. (i'm only paying 150 for a running motor)
smooretahoe
08-14-2015 09:23 AM
JAmdor3
08-11-2015 10:53 AM
4x4-runner
08-03-2015 07:14 PM
Bucksnuff
07-31-2015 07:09 AM
Quick Reply: 1988 3.0 the same as 1994 3.0?
