1988 22re swap with a 1988 V6 3.0 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-16-2007, 04:43 PM   #1 (permalink)
Has anyone done this? In the process of taking out the motors, what changes will I need to make the V6 work in the 22re truck. If there are significant changes could you direct me in the right direction. Any help would be greatly appreciated.
bginaz is offline
Old 04-16-2007, 05:08 PM   #2 (permalink)
breknraj's Avatar
Right off the top, you're looking at engine, engine wiring harness, ECU, transmission, transfer case, and motor mounts all needing to be changed.
If you are seriously considering this, you might want to think about a 3.4 swap, unless you have a GOOD 3.0 already in hand.
I'm not sure, since I haven't dealt with 4 bangers, but I think that the 2.7 might be a more do-able swap. I'm sure that others will let you know.
__________________
Raj : 1960 Homo Sapien. 192cm, Blonde, Blue. Soon to lose spare tire.
Worf : 1990 SR5 Xtracab 4x4 5 speed, Inca Red Metallic. 3.4 converted, with Taco 5 spoke alloys, 275/65R16 BFG AT K/Os. Soon to add rear e-locker.
breknraj is offline
Old 04-16-2007, 05:20 PM   #3 (permalink)
Thanks for the reply I should have stated that I already have the V6 it came from a 1988 that was a roll over so all the wiring harnesses, ECU, transfer case and transmission are all there. What would be the best way to do the motor mounts cut them off the V6 truck and put them in the four cylinder or is there a company that sells the motor mounts?
bginaz is offline
Old 04-16-2007, 05:37 PM   #4 (permalink)
90RunnerRed's Avatar
Quote:
I went the other way. I took a V6 truck and put a 22RE in it. I had to cut the engine mounts and re-weld them. Actually worked out pretty good if you take your time. You'll also have other simple things like changing out the accelerator cable and things like that. You are off to a really good start having the donor vehicle with you. Definitely just unplug the harness from the ECU and pull it through the fire wall leaving everything attached to the engine.
__________________
1986 4Runner, 4.88's, 4.7 Transfer, 3 in Rough Country, 33's (need's some lovin)
1987 4Runner, SR5
1990 4Runner, 22RE, sliders, play pen, 265's, 1998 wheels (SOLD)
1997 4Runner LTD, E-Locker, ISR, Deck Plate, PIAA Fog Lights, (SOLD)
2000 4Runner LTD, E-Locker, Stock (Wife's)
2002 Tundra, Fipk, SS Headers, Flowmaster exhaust, TB Spacer
90RunnerRed is offline
Old 04-16-2007, 07:02 PM   #5 (permalink)
rdlsz24's Avatar
Send a message via AIM to rdlsz24
Quote:
My truck has the same done to it. The previous owner swapped in a rebuilt 2.4L in place of the dead 3.0.
Rob
__________________
1988 Xtra Cab Pickup ('94 22RE; 4x4; 5spd)
Rancho lift w/ 33x12.5x15 tires & 5.29s
rdlsz24 is offline
Old 04-16-2007, 07:50 PM   #6 (permalink)
Hayes's Avatar
Send a message via AIM to Hayes
The chassis' are the same so there shouldn't be much more to it than to just take things out of the donor truck and stick them in the recipient truck.
All the mounts will need to be welded in, and the harness.
__________________
Obama is an acronym.
OBAMA = One Big Ass Mistake, America
Hayes is offline
Old 04-16-2007, 10:16 PM   #7 (permalink)
Really not worth the trouble for that engine, even with it already on hand. You're better off unloading the rollover, and finding another 22re or the 3rze (2.7l 4cyl). It'll be less labor and a better engine.
ohio is offline
Tags
1988, 22r, 22re, 30, accelerator, cable, cruiser, engine, harness, land, motor, mounts, pickup, swap, toyota, transmission, truck, v6, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Toyota Landcruiser: 1988 FJ62 vs 1988 GX 4x4 gmmceo Early Land Cruisers 0 05-21-2006 07:56 PM
1988 4runner, v6 vs 22re gilkey 95.5-2004 Tacomas & 96-2002 4Runners 10 10-04-2005 08:31 PM
1988 V6 gearing questions Ilovemountains 95.5-2004 Tacomas & 96-2002 4Runners 3 05-28-2005 09:02 PM
2009 InternetBrands, Inc.
