1986 22RE Timing Help
Old Sep 6, 2008 | 11:57 PM
86Crawler's Avatar
I have a 1986 Toyota 4X4. I put the engine in yesterday but cant figure out which connectors to jump to time it right. Any help
Old Sep 7, 2008 | 06:43 AM
deserthound's Avatar
On the drivers side fender, it's the smaller round yellow plug with only 2 spade slots.
Old Sep 7, 2008 | 09:29 AM
86Crawler's Avatar
thanks for the response. So I just get either a wire or paper clip to those two spades and I should be able to time it without the computer interfering
Old Sep 7, 2008 | 02:26 PM
abecedarian's Avatar
Yes, that's all that is required...
but you might want to adjust your idle speed too, and recheck your timing.
Old Sep 7, 2008 | 05:34 PM
86Crawler's Avatar
what should I set my idle at???
Old Sep 7, 2008 | 05:39 PM
my 88/5speed says 750. your 86 should be similar
Old Sep 7, 2008 | 06:00 PM
Targetnut's Avatar
when you jump the connector make sure the check engine light flashes steady. If it blinks a code, fix that first. then check the timing.
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
bryan34w
Jul 6, 2015 05:53 PM
karbin
Jul 5, 2015 11:37 PM
