10 bucks to whoever
Old 07-25-2008, 03:03 PM
scuba's Avatar
10 bucks to whoever
Can help me get this rear drive shaft off.
No, seriously.
im not a very strong guy, and this thing wont roll in order to put it on a trailer.
thus being said.
210-902-9054
NE San Antonio.
Old 07-25-2008, 03:08 PM
abecedarian's Avatar
hack-saw, band saw, sawz-all, plasma cutter
circlip pliers
Old 07-25-2008, 03:09 PM
grovedogg's Avatar
hey.. you can't blurt out all the answers!!! lol
Old 07-25-2008, 03:10 PM
drop the center carrier bearing then slide the splines out of the shaft and tie the shaft up.... unbolt the stub from the rear pinion
ooops... sorry.
Old 07-25-2008, 03:11 PM
did I mention mag77 with carbide cutting wheel?
Old 07-25-2008, 03:16 PM
just a 22re's Avatar
what about unbolting the 8 14mm bolts holding it on????
if you did and still nothing then start her up revlimiter and dump it it should pop off nicely lol
Old 07-25-2008, 03:29 PM
eighty5yota's Avatar
[QUOTE=just a 22re;50883134]what about unbolting the 8 14mm bolts holding it on????
its so CRAZY it just might work!!!
Old 07-25-2008, 04:22 PM
scuba's Avatar
Dang, you were thinking exactly what i was.
got some liquid wrench and waiting on my dads buddy to come help.
ha.
is it possible, that after an episode of mudding the rear brakes could lock up ?
Old 07-25-2008, 04:26 PM
Elton's Avatar
make sure u mark the shaft b4 you take it off or you may run in to some vibration issues
Old 07-25-2008, 04:54 PM
scuba's Avatar
Oh there's already a mark of rust on both sides, but good point.
as stated by my stupid self earlier...
Can the rear brakes lock up causing it not to be able to roll??
I can't push it anywhere, then again im not very strong.
But the 6 mexicans that were here earlier couldn't push it either.
Help, i need somebody, HELP !!
Old 07-25-2008, 04:59 PM
well, neutral and no e-brake and can't roll means something's wrong.
Old 07-25-2008, 05:11 PM
scuba's Avatar
Exactly, if it was your truck, what would you take a look at first buddy ?
Old 07-25-2008, 05:21 PM
Junkers88's Avatar
Originally Posted by scuba
Exactly, if it was your truck, what would you take a look at first?
You went mudding and now she won't roll at all? Am I understanding this right? Take a look at the brakes. I had a 3/4 ton years ago that did this and it took pulling the rims/tires and beating the drums with a hammer to pull em. The shoes had soaked up water (and brake fluid from a busted cylinder) and were like JB weld in there.
Just a thought.
If you have someone with a truck have them hook up and try to pull it a few feet with it in neutral and the E brake off.
Might also look to be sure the E cable didn't snag something and lock down.
Old 07-25-2008, 05:27 PM
scuba's Avatar
will do
Old 07-25-2008, 05:28 PM
Yeah E-cable
Old 07-25-2008, 05:29 PM
what the???? ok i say yeah the E-cable check that over and if you can roll it like rocking it in gear and thats all it does then it might be something up in the fly wheel parts? if it dont roll at all the yeah its the rear brakes giving you problems
Old 07-25-2008, 05:31 PM
scuba's Avatar
e brake cable seems to not have a problem
Old 07-25-2008, 05:36 PM
Junkers88's Avatar
Pull it and see if the ass end drags......... my wife does that sometimes after getting "dirty"
Old 07-25-2008, 05:39 PM
scuba's Avatar
yeah, what a solution.
your wife seems like a keeper.
Quick Reply: 10 bucks to whoever
