When going .030" over, what piston to use? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-22-2007, 09:01 AM   #1 (permalink)
LUV24BY's Avatar
I am preparing plans for the build up of another 22RE for my runner. I am eyeing EB's kits, and for a bit of extra ponies I am going to have the block bored .030" (I was told .040" is the most the 22R blocks can have, so I want to save a little for future needs) Here is my delema-
I saw EB has some Turbo Pistons which I could realistically use. I won't be running a Turbo or a Supercharger, however I wish for about 175-200hp. I would like the piece of mind of the added strength and durability if the turbo pistons provide that.
Is there a noticeable difference in the way the standard .030" pistons and turbo pistons are made and there features?? If using the Turbo Pistons without a turbo, does that effect/lower the compression of the engine? I will probably be running a performance 22RE head. I would do the 20R head however the EFI I hear is not a bolt on to the 20R.
Thanks for the knowledge in advance!
John
__________________
My Junk:
1985 Toyota 4 Runner DLX, 22RE, 5 SPD
Mods: 4" TG 47" Front Springs w/ 5" Shackles, 3.5" Super Lift Rear Springs w/ 6" Shackles, TG Cross Over, TG Shock Hoops, 15x8 "Outlaw I" rims, 33x12.50 R15 BFG MT KM's, Doestch Tech 12" DT3000 shocks (4 corners), Custom Front Driveshaft w/ 12" Slip yoke & CV joint ground for higher angle, Toyota Fiberglass front fenders, Centerforce Dual Friction Clutch, SR5 Cluster
My World:
My 1985 4Runner's Profile
My Car Domain Page.
LUV24BY is offline
Old 03-22-2007, 11:09 AM   #2 (permalink)
deserttoy84's Avatar
Send a message via AIM to deserttoy84
running turbo pistons will give you less compression. what you should do is get your 30 over pistons/rings and take em to the machine shop and them bore the cylinder to the pistons so you get the best clearences.
__________________
1984 toyota sr5 4x4
22r w/ weber 32/36
Pro comp 4" front springs & 3" rear downey spring
Home made On-board air system
V6 4.88 lock rites F & R
Bilstein 7100 reservoir shocks
deserttoy84 is offline
Old 03-22-2007, 11:18 AM   #3 (permalink)
LUV24BY's Avatar
That's what the machine shop wants me to do. I just thought the Turbo pistons would be a bit more stout, however if they give less compression then I will stick with standard style pistons.
Thanks for the info DT!
John
__________________
My Junk:
My World:
My Car Domain Page.
LUV24BY is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Piston ring order WesternViking 86-95 Trucks & 4Runners 7 11-04-2006 01:42 PM
seized piston on caliper PoleVaulter95 86-95 Trucks & 4Runners 14 10-25-2006 10:41 AM
what's your piston count? Glenn Off Topic Talk 51 08-13-2006 11:16 PM
Piston Slap? Sonofmayhem 86-95 Trucks & 4Runners 11 07-07-2006 02:12 PM
Piston FIRING ORDER!!! pitm96 95.5-2004 Tacomas & 96-2002 4Runners 1 09-07-2005 11:18 AM
2009 InternetBrands, Inc.
