wheel ?'s
wheel ?'s
what are some good wheels for 85 4runner with 33x12.50r15 pocomp extreme muds? what should the backspacing be? what should the offset be also with no rubbing or no wheel adapter. i have a 3 inch lift by rough country as of right now
well my problem is that my tires are too close to the frame and tie rod so i had to put wheel adapters on to not rub on the tie rod and frame so i am lookin for new rims any suggestions would be great
People say you're supposed to stay within 4" of width, ie, 10.5" tire on no less than a 6.5" rim..but you can go to 6". If put them on too skinny of wheel, then the center is going to bulge out, on too wide and the center will bulge "in". 15x8 is a good size for 12.5" tires.
well on your axle its wider if u have the stock one for your year and wheel adapter is where it bolts on to your stock studs than it has studs on itself to push the wheel out farther so it dont rub
Up&Down
08-05-2015 06:20 AM
Luvmeye22re
08-04-2015 03:53 PM
skoti89
07-06-2015 07:45 PM
