What's this?
I believe that is for the automatic transmission kickdown cable (or I think that is what its called). This tells the transmission when to shift based on the throttle position. My truck is a carbureted automatic and has a cable running from the carburetor to that notch in the bracket then to automatic transmission. Not sure if the notch had any other uses like cruise control... There is probably nothing in this notch for most if not all trucks with a manual transmission.
Not the best picture but here you go:
Dude that's awesome. Would you mind getting a picture of where that goes to on the carb?
I'm trying to find a really good way to hook up a hand throttle on my crawler.
thewhitestallion
10-11-2015 11:40 AM
