What size lift do I have?
The truck has the stock shackles and 3" body lift. But I'm not sure about the springs. It has sky jacker shocks, so im guessing it has a sky jacker lift. Could someone tell what size springs it has I think it has 3" but really dont know. The truck sits right now with the 35's here are some pictures. I want to get bigger shackles for the rear cause it sits 1 inch lower in the rear than the front. Are bigger shackles a good idea and what about the body lift it has on it already? I have pictures of the springs if needed. The rears have some arch to them but the front are really flat.
looks like 3" no blocks right? if you want a fast cheap way to fix sag , search zuk coil mod.
if you want a better way you can go with an add-a-leaf or a new set of trail gear springs or marlins or alcans or allpro.
Stock fender to top of 15" wheel is in the 13.5"-14" range, so measure yours and see:
- http://www.off-road.com/trucks4x4/ar....jsp?id=398514
Subtract the 3" body lift off and any extra height is your suspension lift height.
Longer shackles can give some lift:
- http://www.4crawler.com/4x4/ForSale/Shackles.shtml#FAQ4
justdifferentials
Just Differentials
08-30-2015 08:42 PM
justdifferentials
Just Differentials
08-15-2015 05:25 PM
coffey50
07-28-2015 10:55 AM
