Weber problems
Weber problems
I have an 85 pickup 4X4 with a Weber carb. I'm getting fuel to carb but not in carb . Will only run when I pour had in the car. Can someone help me an d. Not sure what model Weber this is or how to tell
I already answered what it sounds like.......
Check your fuel lines and ensure they are routed correctly. It sounds like you might have them mixed up a bit. IF they are correct, verify that your pump is working. Other than that, I don't see what else it could be.
When you say you "are getting fuel to the carb, but not in the carb" where is it going? I don't see how that is possible. Is your carb super dirty and clogged up?
Theirons84
04-08-2016 05:22 AM
