upgraded rotor, can't find wheel studs!?
So I purchased one of the brake combos from marlin,#2, and I am having a helluva time finding wheel studs that fit. I'm leaning twards m14-1.5. Anyone else have this problem and what size did you use? Any help is useful! Thanks
I called and they said that anything from an 85 would work...but m12x1.5 is too small, they are an 8 hole design. Is this even the right rotor? The size that fit snug are m14x1.5
8-lug? not on a toyota wheel. Unless your talking about 6 + 2 holes for the capture bolts. But even then the extra two holes would be smaller then the lug holes.
P.S. Did marlin take their brake upgrade kits down? Cus all I see is calipers, rotors and masters.
2 bolt holes
6 wheel studs
M12
The studs hold the rotor on through holes on the rotor.
Knurl is on wheel hub and stud not rotor. Same for bolts.
The diameter at the stud head might be wider but the threads are M12.
Wheel hub rotor stud through back of rotor into back of wheel hub
:wabbit2:
6 wheel studs
M12
:wabbit2:
No one else has ran across this before? Guy from marlin said I could get them from any parts store he diddnt specify that they had to be stock. I'm still very confused. I wanted to have the studs already on the rotor so I could just swap rotor and caliper and done
my god you just had two people on here, both being a long time member on here, one of which builds these things every single day and Marlin tell you to use the stock ones you got how much more clarifications you need? Who you gonna believe the person who sold you the wrong wheels studs or 3 people who build toyotas? Take one of your studs out, look at the difference in what you got and try it. Why is that so hard?
The studs don't go IN the rotor.
The studs go through the rotor.
Go here:
www.ncttora.com/FSM
Read replacing rotors.
Use your stock wheel studs.
If need some more go to dealer or parts store.
Follow above instructions in FSM.
Drink a cold beer and quit pushing the Q tips in so far.
You are making this WAY too damn hard
:wabbit2:
Go here:
www.ncttora.com/FSM
:wabbit2:
I think I see what he's trying to do. Have you even taken apart your truck yet? I don't think you have. As you wouldn't be doing what you are attempting to do. I'd be willing to bet you do in fact have the correct studs. Maybe not, but you might. Once you figure out what you are doing wrong your probably gonna be somewhat embarrassed.
06-01-2021 01:51 PM
skoti89
07-06-2015 07:45 PM
