transmission question?
Old 11-07-2007, 11:50 AM
mycool's Avatar
have my 85 pickup with EFI. I believe W56 tranny. 1-5 is fine but reverse is unable to be found. you can put it into reverse and it just grinds and kicks out... can't hold the gear in at all. Is this a hard rebuild or should I get a replacement tranny? any help would be appreciated!
Old 11-07-2007, 01:13 PM
fillsrunner4's Avatar
the reverse gear i believe would be the easiest to replace. its on the back portion of the transmision housings ( belhousing/housing/center section/back housing/tcase) and is only a few gears to work with. to fully rebuilt the transmission youll need pullers, a press, snap ring pliers and a good set of sockets/misc and a magnet would be great. be sure not to lose the srpings and balls and youll be fine. how i did mine was take it a apart slowly, take tons of pics and label everything in order. i even added numbers so i could not lose track and go in reverse order apon reasembly.
Its a great learning experience and its really not that hard to do at all
Old 11-08-2007, 07:51 AM
mycool's Avatar
thanks a lot for the info. i think i might try to do this one myself :-)
Old 11-08-2007, 08:28 AM
bwhyit's Avatar
If your clutch isn't completely disengaging it could cause this problem.
Old 11-08-2007, 02:56 PM
rowdy235's Avatar
Yea, my friends clutch SC was on the way out and his did that. I still think it sounds like a rebuild coming up.
Old 11-08-2007, 03:11 PM
danski's Avatar
before shifting in reverse...go to 3rd gear and then to 4th and then reverse...try that!
chuckross1957
06-28-2019 10:19 PM
mskalmus
05-28-2017 07:51 AM
mYnAmEiSmUd
07-20-2015 06:48 AM
jjrbus
07-17-2015 07:06 AM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: transmission question?
