Timing Problem?
Timing Problem?
The distributor was taken out, so I moved the motor to TDC and put the dist back in, pointing at the #1 cylinder. The motor runs, barely, you need to give it gas for it to start and it will idle at just over 2000 RPMs. If you hit the gas it will sputter really bad and almost die, if you ease into the gas it will rev up to about 4000 RPMs then want to die. Do i need to move a tooth or two on the timing chain, I tried the distributor in a tooth off each way and it wont run. Also, when it sputters or after 4000 RPMs, it will spit gas out of the carberator. This is an '84 22R by the way. What do I need to do. I cant take the whole front of the motor off right now, I need it moved. Do you think its the timing chain off on the sprockets or what? If it is, which way should I turn the top sprocket?
Are you sure you were TDC on the compression stroke? Can you pull the valve cover off? Rotate the crankshaft timing pulley to *5 and TDC#1 compression stoke. When TDC compression on #1 cyl the #1 rockers are loose and #4 are tight. Insert the Dist. with the rotor pointing at 12 o'clock and the hold-down adjustment slot centered over the threaded hole. As the dist. is inserted the rotor will rotate down (counter clockwise) to #1 (approx 10 o'clock). Also check your wires to make sure they are going to the proper plugs.
Hope that helps.
Hope that helps.
the1998sr5
10-19-2016 12:48 PM
jennygirl
11-17-2015 11:24 AM
