Stripped dr. side steering knuckle rotor bolts
Old 07-11-2009, 02:33 PM
johnnyjay's Avatar
Butting the axle back together and bolting on the rotors when lo and behld what do I find but the driver side threads for the rotor is stripped on the knuckle.Now I dont know what to do! Do I or can I drill/tap the knuckle? Or any other options do I have? Thanx John.
Old 07-11-2009, 02:59 PM
85TurboRunner's Avatar
Do you mean the caliper bolt holes? If so, yes to can helicoil them. I had one strip out a while back and I used a helicoil on it and haven't had a problem since.
Old 07-11-2009, 03:16 PM
johnnyjay's Avatar
The bolts that hold the rotor to the knuckle. The pass side is fine thread and about 2 inches long and 1/2 inch wide.
Old 07-11-2009, 03:27 PM
1989toy4wd's Avatar
There are bolts that hold the rotor to the hub?? I dont think you need those...I was always under the impression that the wheel held the rotor to the hub! Unless you have the bearing races built into the hums, then the nut and cottor pin hold it in right??
What kind of truck is it?
Old 07-11-2009, 05:04 PM
waskillywabbit's Avatar
The rotor does NOT bolt to the knuckle...period.
The rotor does bolt to the wheel hub with 2 bolts and then has 6 wheel studs drive through it. I don't know that it is that big of an issue since the 6 wheel studs hold it on by themselves. A new wheel hub shouldn't be hard to find.
And there are no 1/2" wide bolts on a Toyota.
Old 07-11-2009, 06:01 PM
johnnyjay's Avatar
O.K. the brake caliper has 4 bolts in it. 2 at each end that go from one side to the other side of the caliper. Then there are 2 bolts that are closer together that bolt to the knuckle to hold (what iam guessing) the caliper in place. Those are the ones that are stripped, the previous owner just placed the two 1/2 bolts in place to get it to my house. So can I drill/tap the knuckle? Or do I have another option?
Old 07-11-2009, 06:09 PM
You can buy another knuckle (they are side specific) for about $30. Or you can helicoil it.
Then go back to the POs house and punch him in the nose.
09-04-2015 09:27 AM
msane99
07-11-2015 08:08 PM
jon.r
07-11-2015 03:34 PM
smiley52
07-11-2015 05:16 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: Stripped dr. side steering knuckle rotor bolts
