shell remove 4runner
Old Jul 11, 2006 | 02:41 PM
panchobarba's Avatar
Hi is anyone has tips for “easier” remove a shell (4runner 86)
Old Jul 11, 2006 | 04:19 PM
getitdone's Avatar
Search through here you will find something.
4crawler.com
Old Jul 11, 2006 | 05:36 PM
Hayes's Avatar
yeah take the bolts out and lift it off
Old Jul 11, 2006 | 05:58 PM
Dingman's Avatar
Aren't you smart Mr. Hayes. - Quite helpful also.
I have attached straps to the rafters in the garage. I park under them, then lift each corner and run the strap underneath and then back up to the ratched on the other rafter. I ratchet the topper up and just let it hang there. I find that since that space in the garage isn't *ever* used otherwise, it's an excellent storage spot for the topper. Obviously, you can still park your truck just under the topper all summer long.
I could take some pics if you'd like but I'm sure that you get the idea.
HTH.
Old Jul 11, 2006 | 06:03 PM
Hayes's Avatar
I wasn't trying to be a comlpete ass......but that's the only way to do it, your's is more a storage suggestion than a removal suggestion.
Old Jul 11, 2006 | 06:12 PM
Dingman's Avatar
Not a prob... I sure have my moments, as you can see.
Old Jul 11, 2006 | 06:39 PM
Jimmeh's Avatar
I would like to see them, if you don't mind. Just in case I get another first gen some day.
Old Jul 12, 2006 | 05:20 AM
4Crawler's Avatar
I use the straps to both remove and store mine:
- http://www.4crawler.com/4x4/4R_TechI...tml#TopRemoval
Old Jul 12, 2006 | 05:26 AM
Intrepid's Avatar
Since I don't have a garage, I remove the bolts, slide it off the back and put one end on the ground (leaving the other end leaning on the truck), then I tilt it up, get underneath it, grab a grab handle with each hand, let it sit on my back and lift it and carry it to where I want it. The only thing you have to watch out for is if you are not on flat ground, when you slide it back it may slide off the side and gouge your paint. Been there done that fixed it with rattle can. I solved this whole issue with an STC though.
Old Jul 12, 2006 | 08:40 AM
:bigclap: Ohhhhhhh great tip thanks
Old Jul 12, 2006 | 08:46 AM
Hayes's Avatar
it's honest and it works...
Old Jul 13, 2006 | 12:02 PM
93ToyKid's Avatar
be CAREFUL taking that thing off!! me and my dad took ours off, and somehow it fell off the side of the runner, thus pinning my fingers between the sharp plastic edge on the inside and the side of the truck. all i could do was let the thing slide to the ground. cut one finger on my right hand to the bone, and cut all the others on my left hand. and on top of that, it left a nasty scratch down the side. i was pissed...
Old Jul 13, 2006 | 05:09 PM
Hayes's Avatar
my girl was helping me and it smashed her wrist...gotta be careful
Old Jul 13, 2006 | 07:42 PM
Sonofmayhem's Avatar
Yeah i gouged the chit outta my headliner, gotta be careful... i like the rafter idea, but i have bikes hanging where i park.
icentropy
Sep 16, 2020 02:47 PM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
ItsJustD
Jul 7, 2015 07:49 AM
HRDC0R19
Jul 5, 2015 06:43 PM
