Seized pistons
Old 02-26-2012, 03:31 PM
85RunnerSR5's Avatar
Seized pistons
I found a 1st generation 22r long block behind my neighbors house in the woods. It appears it has sat for years in the weather. I tore it all down but can't get the pistons out. From what I could tell, it appears that someone stuck a pry bar in one of the cylinders and hammered on it to get the piston out of the cylinder and failed, which makes me think that they let it run hot and seized the engine.
Is there anyway to get them out? Or should I just scrap everything for a decent block? I sprayed PB blaster on it and let is soak then tried to hammer them out but they wouldn't budge. Any suggestions would be helpful.
Old 02-26-2012, 03:39 PM
rokblok's Avatar
I think if it's seized that bad, I would discard it. You will probably do irreparable damage if you attempt removal of the pistons more than has been done already. Although it would probably piss me off and make me more curious so I would do everything I could to get them out....
Old 02-26-2012, 04:32 PM
lethe's Avatar
scrap it and find a block that hasnt been sitting in the elements for a few years.
Old 02-26-2012, 06:44 PM
skoti89's Avatar
pics or it didnt happen
Old 02-26-2012, 07:25 PM
totally a bro
Staff
vital22re's Avatar
soak and heat them up
bigger hammer.
Of course I wouldn't use that block... but for giggles why not get them out?
Old 02-26-2012, 07:49 PM
yeah I agree with you guys...I'm gonna find another donor. Thanks for the input!
ladybugRC
458
08-21-2020 10:41 AM
Firefightersink15
11-23-2015 10:32 PM
charlie_fong
09-27-2015 10:06 PM
old87yota
09-09-2015 12:39 PM
seab1209
09-03-2015 05:41 PM
Quick Reply: Seized pistons
