Replacing Clutch
Replacing Clutch
I'm the proud new owner of an 84 4runner which is in need of a clutch replacement. 1st off I know nothing about Toyota's. So, is it easier to pull the transmission and transfer case together or seperately. I am doing this in my garage without the aid of a lift or anything except basic hand tools, jack stands and a small hydraulic jack. If pulled together can the combination be handled by 1 person?
i pulled both just using a floor jack it wasnt to bad i had help taking it apart but i put it back together myself without to much trouble but its alot quicker and easier with help. and the starter blots to the bell housing instead of the motor which still doesnt make sense to me but u have to take it off to separate the 2
If you can rent a tranny jack or one of those floor jack adapters DO IT!! lol! You don't have to but it'll make life a little easier! I pulled the tcase off and then dropped the tranny by myself with some jackstands. I put it back in as a whole and, well, that was interesting! LOL!!
when I pull the tranny which it seems to be alot these days I get all the bell housing bolts, un bolt the drivelines, unbolt the shifters, undo the electrical stuff, undo the Speedo, then support the transmission and transfer with a tranny jack and get the 8 x member bolts out shift the tranny jack back to clear the the input shaft from the clutch assemble and drop it down to the ground.....now I will pretend I am a Chilton's manual....to REASSEMBLE repeat steps in reverse LOL
Well GL anyways have fun with the two upper 17mm bolts on the top of bellhousing
Sponsor
you need a TON of extensions and a wibblewabble at the end for the 2 top bolts.
goto harbor freight and pick up their $120 tranny jack.. so worth its weight in gold compared to bench pressing the tranny out or trying to use a regular floor jack
then go to a farm outlet or something you need a cheap tranny jack makes it alot easyier but if you have a second or 3rd pair of hands and a few floor jacks you can make it work
When you get to the pilot bushing, cut up chunks of wax, feed into it, and hammered in with the alignment tool will push the bearing out.
I think I use a 24-36'' of extensions to get to the top two bolts, and about the sdame to get the starter bolt, and nut off, coming in from the front end.
Good time to change the rear main seal, and the front transmission seal.
wtf is a wibble wabble lol, i benched the tranny bellhousing and tcase on my tacoma talk about a pain in the ass this should be lighter though hopefully i dont want to spend the money for a tranny jack...
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
