replacing cam
Old 09-13-2015, 01:12 PM
bigtoy83's Avatar
replacing cam
Can you replace the cam without seperating the head from engie block? I know you need to remove head bolts but after installing a new cam can i just put the bolts back in and re torque them?
Old 09-13-2015, 01:14 PM
bigtoy83's Avatar
I forgot to mention its a 22re
Old 09-13-2015, 03:56 PM
millball's Avatar
Some claim success with not removing the head.
It's not something I would do to my own machine.
The safe thing to do is to remove the head, clean the head and block deck, and install a new head gasket.
It would be a good time to replace timing chain and guides if needed also.
Old 09-13-2015, 07:33 PM
Staff
Terrys87's Avatar
Best bet would be to remove the head, but I did ratchet strap the head down one time to swap camshafts and it has held up.
Old 09-13-2015, 11:05 PM
wyoming9's Avatar
Red face
Do you feel Lucky ???
I know my luck it would leak as I poured coolant back in it would just pour out.
Old 09-28-2015, 07:07 PM
Obmi's Avatar
This guy did.
[YOUTUBE]
[/YOUTUBE]
Old 10-03-2015, 06:09 AM
nordicwargod's Avatar
Its a gamble, lots have done it. But........you may have to tear it apart if the HG starts leaking. I would watch my temperature gauge and check fluids very often afterwards.
bigjstang
08-25-2021 12:41 AM
thefishguy77
07-30-2015 10:59 AM
TURBOrunnerNM
07-22-2015 11:01 AM
1994toyota
07-17-2015 03:03 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: replacing cam
