installing stereo head unit
Am I missing brackets or something? Unit goes I'm good but there is nothing to hold it in place? Says 4 screws will mount it in place but I have nothing to pit screws in..
You need these: The eBay listing wants $40 for them. Ask on here. Someone is bound to have them cheaper!
http://www.ebay.com/itm/1984-1989-Toyota-Pickup-Pick-Up-Truck-4Runner-4-Runner-Dash-Mount-Radio-Brackets-/261271436887?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cd4fdbe57&vxp=mtr
Was just looking at them...thanks! Now leads me to my next question. Hooked up wiring harness...just to see if I could get some juice...no juice. Got everything colored matched. Only thing I'm not sure of are these extra connectors in my truck...pics below. I'm guessing one is a antenna.
I'm not sure if this helps. It's been a while so I'm not sure of your question.
http://www.installdr.com/harnesses/toyota-wiring.asp
I did want to mention that it's a good idea not to trust the ground wire in the Toyota harness. I cut mine at the stereo and ground off a little paint on the dash metal and screwed it directly to that. That was after I kept blowing fuses. Bad ground on the harness. I'm not the first to have that problem. Oh yeah "no juice" when you have everything hooked up properly is probably a bad ground too!
I'd replace the fuse to start. Look for frayed wires that are hanging on by a strand or two. You used a chassis screw for the ground when you pulled this voltage?
