How long do Detroit's Last? Found a deal...
I found a buddy of mine who has a Detroit for a Toyota 8" and it has some miles on it (not sure how many), but he said it was running strong when removed. It is a full Detroit, not a soft locker. There are no clutches to wear out. He said it should be good to go and would take a couple hundred for it.
The R&P gave on his 3rd, so he just replaced the R&P and got a new Detroit.
What should I look for to indicate problems?
Thanks!
John
Thanks!
John
sounds fishy John. Most would just replace the R&P, sounds like something was wrong and he is trying to get some coin for it. BUT, if you trust the guy, I say go for it.
I dunno, I was going to go see it tomorrow. That is why I wondered if there is anything that can be watched for.
John
Never had a Detroit before. Just Lock Rites.
John
John
Thanks for all the input guys! I appreciate it! I will be checking it out today and if all looks good, be picking it up possibly.
Thanks again!
John
Thanks again!
John
just my personal opinion but i'd put it in the front. = less wear and tear, and you only use it when you really need it, i.e. locking the hubs and engaging 4wd. other than that, you are putting un-needed mileage/wear on it.
i like being able to wheel in 4 hi/lo with hubs unlocked until i start getting bogged, then i engage the front. if a locker is in the front when its called into duty... its go time!
Welp, I bought it. $200 - and the reason the guy didn't reuse it is that he went from a 4CYL 3rd to a V6 3rd. The locker is specific for a 4CYL. It looks like it's in good shape, it is one of the older Detroit Hard Locker's. I am happy - got 1 locker down, now one and some gears to go!!
I'll post some pictures up soon in he Build Up Thread!
John
jasonty
41
12-23-2018 01:00 PM
jerusry
10-19-2015 05:28 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
Poncho0206
07-10-2015 06:21 PM
