head gasket job,trying to remove exhaust manifold
Old 06-24-2012, 05:21 PM
Roofmaster's Avatar
I cant seem to get the exhaust manifolds off the heads so I can remove heads to replace head gaskets.I tried at the crossover behind the heads also.Heated the two I could reach and got them free,now Im dremeling the one I cant get the torch to or even a wrench on.This is my last step so I can get heads off and start rebuild.Been at it for 3 days solo and Imgetting frustrated.Help.954x4 pickup 3.0 V-6
Old 06-25-2012, 01:00 AM
kiwicowboy's Avatar
Those are high temp lock nuts on the studs. Use a nut splitter or coat them with WD-40 and let soak.
Old 06-25-2012, 02:47 AM
rokblok's Avatar
PB Blaster is better in my opinion...
Old 06-29-2012, 04:27 AM
Roofmaster's Avatar
Ended up Dremel cutting 4 of the nine
I wish I had just cut all nine of them.After dremel tool cutting the four Icouldnt free up I drilled them out and replaced them with nuts bolts and lock washers,it was ten times easier than putting the stock nuts on the other five.If I ever do this again(hope not) I will cut them all.
Old 06-30-2012, 08:42 PM
rokblok's Avatar
I hope you used antiseize on the threads... It will save a lot of future headaches.
the1998sr5
15
07-14-2020 08:35 PM
Colington
03-08-2020 09:51 AM
09-04-2015 09:27 AM
Coreyr384
07-10-2015 11:13 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: head gasket job,trying to remove exhaust manifold
