coolant in my intake
ok i just got my 22re motor running again.. i noticed coolant coming out of the intake hose.. what could this be? i was thinkin mixed up some vacum lines and stuff but i think they are all right.. any other ideas?
well i am pretty sure all the hoses are on the right spot.. labels and book says i got em all right.. and what i mean by intake hose is the line that goes between the mass air flow sensor and the efi unit or whatever its called
coolant in the large duct which runs over the top of the radiator fan?
it's possible the auxilary air valve (under the throttle body) is leaking internally and the pressure in the cooling system is pushing water up into the throttle body where it then is running towards the air filter.
yep coolant in there.. ok ill check that out tomorrow.. i read somewhere that it could be the intake manifold gasket? is that mabe a possibility?
ok the aux air valve is a small black little thing with 4 hoses and a wire running to it? if so yeah the coolant is being pushed up the hose into the throttle body.. but i had a spare one of these lying around and switched it out.. no diffrence.. is this supposed to be electronically controled?
ok found the problem.. main vacumm line and a bypass coolant line were mixed up.. way hidden underneath.. when i crawled under and looked i knew that wasnt right ahah.. now its only runnin on cylinders 2 and 3 though..
spark at the plugs.. dunno what else to do..
runnermedic
13
09-21-2015 05:20 PM
_Nicco_
09-21-2015 03:06 PM
LotOMiles
09-14-2015 11:45 PM
