coolant leak from hose under power steering pump
I have a leak from this hose and was wondering where would be a good place to get a replacement? I'm sure a typical single size diameter would work, but I do know the hose has a slight flare out on one side, which I think would cause some problems if I were to get a hose w/a single size diameter.
I'm thinking the best would be to get an oem replacement unless someone else has a different opinion.
Anyone know where to get a replacement for this? Thanks
I almost always go oem. That or Napa or Carquest. They all have the right part. You may need to cut it to fit, but they'll know the right diameter for your truck.
Uhm...Toyota dealership?
I don't really get why you're worried, though, unless you have a non-stock weird set up in your truck. The aftermarket is out there to fill our needs...therefore they supply the parts for your truck. If there is a coolant hose on our trucks which has one end larger than the other (I've never seen one on my truck, I don't think..) then most likely someone other than Toyota is supplying it. The parts place has a database and they look up your model truck, your model engine, and get you what you need. If what they hand you doesn't look right, then let them know.
06-01-2021 01:51 PM
TURBOrunnerNM
07-22-2015 11:01 AM
Avenged
07-09-2015 07:55 AM
skoti89
07-08-2015 12:05 AM
