cam shaft question
Old 04-02-2011, 08:11 AM
firewood's Avatar
cam shaft question
i have an 85 22r just bent a valve im wondering what would be a good cam for a moderate power up grade and still not lose to much gas mileage and does anybody have one near portland oregon they want to part with
Old 04-02-2011, 09:27 PM
Broknbonz's Avatar
the truck i bought has some type of RV cam in it that was installed by the previous owner when he had the engine rebuilt. It seems to run very good with alot more bottom end power than several of my buddies 22re motors. I'm currently out of town but when I get home tomorrow night I'll look through the receipts and see if I can find the Brand and specs for you
Old 04-02-2011, 09:40 PM
baddest94's Avatar
Check www.lcengineering.com they have a lot of differant cams. Thats where i got my cam from dont remember the exact specs on it but its the offset cam for the 22re they run around 160 if i remember correctly. From what i have done to my truck the best upgrade was the putney's preformance head www.22repreformace.com, the second would be the header and 3in exh, then supra afm swap, then the cam, and last the throttle body spacer. I would try and get the intake and exh opened up before going with a cam. Thats my opioin on it
Old 04-10-2011, 05:02 PM
firewood's Avatar
ok thanks for the tips ill do more research and se what i come up with
Old 04-11-2011, 10:43 AM
JonnyBoy's Avatar
If you're in Portland area, you should check out engnblder. He's got quite alot of experience with Toys and is in the area.
bigjstang
08-25-2021 12:41 AM
A2theK
01-10-2016 10:18 AM
88sasturbotoy
08-11-2015 01:56 AM
thefishguy77
07-30-2015 10:59 AM
cgilley
07-25-2015 10:55 PM
Quick Reply: cam shaft question
