YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-06-2008, 10:51 AM   #1 (permalink)
nomiss05's Avatar
brake lines?
are certian brake lines better than other brands? im getting a 2" lift in the front and need to put longer lines on my truck but i dont know if there are things to look for or things to stay away from. also do you know what the stock length is for the 85pu?
nomiss05 is offline
Sponsored Links
To remove this ad, register today!
Old 09-06-2008, 11:04 AM   #2 (permalink)
4Crawler's Avatar
Stock hoses should be fine for a 2" lift. You can measure the lines you have for the stock length. You can get s/s replacement brake lines, a DOT approved version would be the best.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
New brake lines, now soft brake pedal PCE91V64x4 86-95 Trucks & 4Runners 3 01-21-2008 05:41 AM
brake lines CraZyRunner 86-95 Trucks & 4Runners 3 08-17-2006 06:26 PM
Brake lines... grn95runner 95.5-2004 Tacomas & 96-2002 4Runners 8 07-04-2006 03:52 PM
SS Brake Lines turboale 95.5-2004 Tacomas & 96-2002 4Runners 12 12-15-2004 05:27 AM
Brake lines.... Ducky 95.5-2004 Tacomas & 96-2002 4Runners 1 05-17-2003 09:08 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
