best way to move front axle forward?
what is the best way to move a front axle foward? ive heard that i should move my perches but i dont understand how to go about doing this, help?
84 4runner 4.5 in. lift, 33x12.5
Use rear springs on the front. That should move it up a couple inches.
Check out pirate4x4.com for the writeup. Im sure you could even find one here, somewhere.
-Brian
-Brian
i just put a set of rears up front tonight, they were pretty saggy and now the shackles sit on the frame, do i just need longer shackles?
you sid there was a write up on pirate, i couldnt find it
Look in the Toyota 4Runner forum in the FAQ at the top of the page...or scroll through the pages as the "Rears up front" thread stays pretty active.
We have lift kits etc if you decide to go that route.
The way this works is the pressed in center pin goes into the existing hole in the spring perch (to locate it) and the head of the spring's center pin goes into one of the two new holes. The holes are typically set up for 3/4" and 1" offset, so you can pick either offset depending on how you orient the plates. Custom offsets, up to around 1.5" are possible. More info:
- http://www.4crawler.com/4x4/ForSale/...elocationPlate
Best option is to just redrill the front spring perches, won't add any thickness to the springs, which is the big limiting factor w/ stock steering. Be sure to look at both perches before drilling as one may have existing holes in it. If so, drill a matching hole in the other perch and then drill a new hole in the top spring clamp/bump stop bracket. I did this (3/4" as I recall) in my '85 w/ stock steering.
I already have a set and I just burnt all the skin off my left hand so I was kind of hoping for a bolt on fix since I'm a gimp but if I don't get any positive feed back about it before I am back to full speed I'll definetly give that try and save them for the rear. thanks.
jerusry
10-19-2015 05:28 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
crashburnoveride
07-10-2015 06:39 AM
