84 Carbed issues
supposed to get this thing smogged this month...
so I hope its all fixed by then..
I may toss on a weber carb, I'm getting for cheap and see if I pass visual and sniff with that..
but either way it would be great to have you look at in dec.
Originally Posted by fustercluck
6 hrs from Phoenix to SD right?
final destinations?
does it stay runnig yet?
Originally Posted by 4runnermt
Sounds like you may be getting too much fuel? Or you have leaky carburetor gaskets? I would rebuild the carb for sure. A kit is probably only 25 bucks at any parts place. Then I'd check all of the vacuum lines. Are the spark plugs wet, or fouled? Does it smoke when its running bad?
I would like to find another carb for cheap and rebuild it... a little worried about messing up this one..
my 84 22r carb motor will warm up just fine at about 1500(choke set) then it will idle to liek 200rpm for a few seconds wanting to die then the idle goes to 900(choke opens) might just be a little dirty carb. mine runs fine after that. these engines are sometimes tricky when there cold. eletric choke sometimes doesnt like to work like it should.
