84 22r will not start
First thing is i swapped a new rebuilt 22r. Then I couldnt get it to start, so i brought it to a shop. I drove it home and then the next morning I went out and then it would just turn over and not fire :cry: . So a new carb and coil/igniter later I still Cant get it to start back up . At the shop they redid some wires and fixed the timing. Also it is not getting spark from the coil. But it is a new coil. What should I do?
Check the signal generator. It's the green plug that comes out of the distributor and leads to the coil. Test the resistance from the plug that leads to the dist, not the one that leads to the coil/ignitor. It should read 140-180 ohms.
