22R Power Steering help
ok, I'm putting power steering on an '85 Pickup, and I'm confused. which side of the engine block does the power steering pump go on? the intake side(left when facing truck), or the exhaust side? I see three tapped holes on the block on either side, but the reservoir is on the right side of the engine bay, so where does the pump mount to?
I THINK I have both brackets. What I have is a bracket that the pump mounts directly to, and then the idler pulley. Do I need another one? thx for the reservoir hose length, I was gonna have to figure that out after I mounted the pump.
I just added power steering to my 85 truck, i didn`t have the y shaped bracket, i didn`t know about it until now, and in my opinion the y shaped bracket isn`t needed. the pump and idler pulley are mounted to the engine with all the other brackets and bolts and is very solid.
whereAreMyPants
07-22-2015 03:32 AM
jon.r
07-11-2015 03:34 PM
