rust on block before head install
a few months ago i tore down the motor to fix a cracked timing cover from an old "mechanic" "fix". work took over, had to move, and the truck got moved outside of the shop over the winter. now i finally have the time to finish it up (i quit my job, its amazing what you can get done when you aren't working 50+ hour weeks) and want to get it put back together this weekend. when i stopped the project the head was off so the bare metal on the block and cylinder walls has started to rust. it doesn't look very bad, but it is concerning. i figure a wire brush should remove the rust from the top of the block but i'm really concerned how to clean up the cylinder walls without damage. should i just throw a bit of oil into the cylinders and hope the rings free up from the walls, and let the piston clean up the walls? or any other ideas?
Al
Al
it almost seemed to rub off with my finger, a friend suggested some steel wool and wd-40. i think that should work?
hey robb, yeah i finally am getting back to it. i got a rude awakening when i got the dmv letter about renewing the stickers in april. i ended up pulling the block yesterday. unfortunately i have to reinstall the timing cover as the chain shifted off half the bottom sproket and is pinched against the cover... doh! (that's originally why i lost motivation, but the move sealed its fate) but now with the block out i can put the head on easier and get the block and engine bay degreased to match the pretty shiney timing cover. i tell ya, fixing oil leaks was overrated apparently. i bet she looses 20 lbs of weight after i get all the crud cleaned off.
Al
09-04-2015 09:27 AM
jon.r
07-11-2015 03:34 PM
