power steering pressure fitting leak
I just put power steering in my 80 pickup using all used parts. the pressure line fitting to the gear box is leaking from between the metal tube and the nut (dont know what elses to call it). I tried a new pressure line and the new one leaks in the same way. the line will still move and swivel when the fitting is tightened all the way down. the threads dont appear to be damaged in the gear box. why is this thing leaking. the instructions in my book for removing and installing the gear box dont say anything specific about the pressure line.
thanks for any help
thanks for any help
Was it an OEM line to start with or did you match the fitting and make a new aftermarket line? Sounds like the wrong flare on the compression fitting so it's not sealing all the way.
:wabbit2:
:wabbit2:
the first line i tried was the line that came from the wrecking yard with the PS pump. then i tried a brand new one from autozone and it leaked the same way.
I'm having the same problems with this.. Did you get it fixed?
There is a removable metal 'gasket' inside the gear box connection that mates to a flat metal surface on the box, and a flared (45deg) metal surface on the power steering line. everything seems to be snug, and I removed that metal piece and cleaned both surfaces.
The pump side of the line has no problem at all, just the gear box. I swapped sides of the hose and it still leaks just from the gearbox side. It looks like the flared surfaces mate fine, and tighten down fine as well.
Any ideas?
Any ideas?
Any ideas?
Any ideas?
jon.r
07-11-2015 03:34 PM
skoti89
07-08-2015 12:05 AM
