YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Pre 84 Trucks
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 10-10-2008, 07:01 PM   #1 (permalink)
kdo58's Avatar
oil passages
I have rebuilt a 22r I am getting oil to the oil filter, there seems to be a blockage after the oil filter, is there a diagram of how the oil flows through the block?
__________________
1981, 22r, comp cam 280, weber 38, stage 1 porting,31" toyo mud.
kdo58 is offline
Sponsored Links
To remove this ad, register today!
Old 10-11-2008, 10:28 AM   #2 (permalink)
Sked's Avatar
How do you know its blocked, I dont have diagrams but when my block was in the shop they took out 2 allen head bolts on the bottom of the block and forgot to replace them and i had no oil pressure.
Took the oilpan off and blocked off those two passages and its good as new.
__________________
81 shortbed 4-5" Lift, 4.37 welded front/rear, custom flatbed on 35x14 mudders
20r bored .060 w/ wiseco 9.9:1 forged pistons, Weber 38 outlaw
260 Comp Cam .440lift ,Crane Springs, 22r Valves, Pacesetter Header with a Flowmaster 40
Sked is offline
Old 10-11-2008, 11:25 AM   #3 (permalink)
jason191918's Avatar
Send a message via ICQ to jason191918 Send a message via AIM to jason191918 Send a message via MSN to jason191918 Send a message via Yahoo to jason191918
Is it the same as the 22re?
http://www.ncttora.com/fsm/1993/engine/54descript.pdf
__________________
JASON
1992 Pickup V6, 4x4, 5 speed, SR5, 300,000 miles young, every option except automatic tranny
31x10.5R15 | K&N FIPK | Cherry Bomb | 3" BL | 4 110W KC Light Bar | 6'6" Western Plow | 800W 10" Sony | 850W Sound Storm | 2 4" Obcon | 4 1" Rockford Fosgate Tweeters | 2 High Pass Crossovers | 2 High-Low Pass Crossovers | 2 6.5" Rockford Fosgate | Pioneer 4x50W Head Unit | Mechanical Oil Pressure Gage | Lack of EGR
Quote:
Originally Posted by Elvota View Post
Jason is right.
Quote:
Originally Posted by fishon1213 View Post
Jason rocks!!! :banger:
jason191918 is online now
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
converting to Mobil1 next oil change, would you recommend drop the oil pan TC4RNR 86-95 Trucks & 4Runners 28 01-08-2008 08:27 PM
Questions about oil pressure and oil pump replacement on 3VZE ThomasJ 86-95 Trucks & 4Runners 2 11-28-2007 05:39 PM
Oil pressure & Trans Oil Temp Install ?? Jayota 95.5-2004 Tacomas & 96-2002 4Runners 0 07-18-2007 08:59 AM
Oil pressure & Transmission Oil Temp Install ?? Jayota 95.5-2004 Tacomas & 96-2002 4Runners 5 07-16-2007 10:13 AM
3vze...what are these passages? Bumpin' Yota 86-95 Trucks & 4Runners 10 07-05-2006 12:56 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
