Pre 84 Trucks 1st gen pickups
Name that front end clunk...
Old 02-07-2013, 02:19 PM
fdizzz's Avatar
I have a 81 4x4, I just installed my trail gear highsteer. Everything seems great except when I have it in 4-low and even a little bit in 4-high on the pavement, something from the front end clunks when I Make a slight turn. It does it a lot more in 4 low and is a lot more noticeable than 4 high. Now when I have 4wd engaged off road I don't notice this at all? Any ideas? Is it just because im on the pavement its doing this? I'm kind of thinking I didn't get the right pre load on my knuckles when I installed the steering arms...
** Oh and it doesn't make the clunk when im going straight**
Old 02-07-2013, 02:26 PM
StewsRunner's Avatar
I know that being on pavement will have something to do with that but i'm pretty sure there is more too it than that. 4hi should be totally fine on dry pavement unless you're turning into a parking spot, then you'll feel it. I probably just told you what you already knew, sorry i'm of no help.
Old 02-07-2013, 02:36 PM
fdizzz's Avatar
Yeah, I know your not spose to have it in 4-low on pavement but I was coming off the trail across my property and slightly turned into my driveway and noticed it.
Old 02-07-2013, 09:38 PM
tditoyota's Avatar
I don't know if this could be the case, but your birfields might be making that noise. Something to do with the gear oil getting into the that area, or lack of lube.
Old 02-08-2013, 02:31 PM
fdizzz's Avatar
Yeah I think I'm just going to rebuild the whole front end... Badass TDI build you have going, I have a 2.0 TDI Golf.. I would love to swap a 1.9 into my yota some day.
Old 02-09-2013, 12:54 AM
James Woods's Avatar
I second birfields.
Flying91
45
04-11-2024 04:39 PM
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
Daneums
08-20-2015 05:36 AM
88sasturbotoy
08-11-2015 01:56 AM
Quick Reply: Name that front end clunk...
