Lincoln Locked
Yup a Lincoln lock is a welded diff. I've seen several of them and they function just like a full spool. If you have a LL front then you'll need to unlock one hub to turn unless you have FL (fork lift) steering. I had a pair (spools) in a scout several years ago running 4:88's and when the FL popped you couldn't turn worth a darn. Same thing with LL diffs. A LL rear is, in my opinion, the cheapest/best way to get a locked rear. It also works really really well.
I ran welded rear for 2 years, and the front 1 year. Couldnt ask for better traction, but turning was a pita. On tight trails i had to keep jumping out and unlocking my hubs, but the welded rear went as far if not farther then my truck in 4wd with no lockers before. Only real prob i had is driving on the streets was loud and took its toll on the drivetrain. Tire wear/ rear wheel bearings/ rear driveshaft u-joints.
yeah a few guys in my club beat on full size trucks welded up... a there are 3 4runner with welded rears and they all love them....im getting the local guy taht weldeds them up to do mine for 100 bucks..i drove my buddys welded f-150 and the offroad performance is so worth the little chirp and the stares
PNW94Runner
09-29-2015 02:55 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
zz_denis
09-06-2015 03:43 PM
