Pre 84 Trucks 1st gen pickups
Lifting with just blocks
Old 05-29-2008, 01:43 PM
Staff
DeathCougar's Avatar
I think you should go post this question on: http://www.pirate4x4.com/forum
They would likely know a lot more about lift blocks and such.....
Old 05-29-2008, 02:17 PM
KellyKel's Avatar
Old 05-29-2008, 02:26 PM
scuba's Avatar
X2 to Deathcougar.
ha
Old 05-29-2008, 04:07 PM
slacker's Avatar
I just wonder ?????
how many of you people have actually used them ?? or are going by
"hear say" ???? or what pirate says .. sheesh !!!!
I ran them in my old rig for 12 years 36" swampers , ARB's and 5:29's .. drove the cr@p out of it .. with never a problem .. if done right , there fine .
I know a spring is absolutly the best option ..but in some cases , a block is required , If done correctly , they work !
in the front .. Absolutly NO ..
Old 05-29-2008, 04:16 PM
  #25
Staff
Must be that canadian logic....
Good that they have worked for you.
But i have seen the destructive opposite.
Old 05-29-2008, 04:19 PM
  #26
Al's Chop Shop's Avatar
Originally Posted by slacker
I just wonder ?????
i have a set of 2" blocks in the back of my FSJ right now, but i don't get spring wrap (at least not with the old motor and auto trans). i have a set of 2" rear springs i just have to pick up in gig harbor, washington that will eliminate the blocks because i figure with the fuel injected chevy motor in front of a manual trans i dropped in....it will deliver just a bit more power and may wrap the springs.
the reason i'm so against them on a toyota is because the axle wrap is so bad even without blocks, those blocks are going to make it sooo much worse. i can't even get a one-wheel-peel because the wrap is so bad on stock springs in the toyota. a block would probably damage the springs. only way i'll run a block is if axle wrap is 100% gone (AAL or bam bar) and never more than a 2" block for saftey.
Al
Old 05-29-2008, 04:34 PM
  #27
slacker's Avatar
so in this case .. what happens when you add a "chev" spring swap ??? 63's ??
seems to me the spring would "wrap" even more !!
all i'm saying .. is different strokes , for different folkes ..
Old 05-29-2008, 05:35 PM
  #28
AxleIke's Avatar
My posts were from personal experience.
Blocks are dangerous and damaging.
Old 05-29-2008, 06:36 PM
  #29
Sponsor
Tofer's Avatar
my post is from personal experience... i have them and i hate them. TONS of axle wrap, dangerous and dumb..... BUT they were a quick fix and they've work since. (knock on wood)
Old 05-29-2008, 07:27 PM
  #30
seafarinman's Avatar
Wow, I can't believe you posted this here. But the premise is correct anyways. If you can afford a big expensive diesel truck, why skimp on the suspension?
Originally Posted by 91Toyota
Every time I see a lift on a street queen I see blocks in the rear. Brand new truck but blocks. What cheap b@st@rd can afford a $50k diesel but can't afford another $600 for springs? Springs are the way to go. I bought them for my chevy too. Blocks are for fags
Old 05-29-2008, 07:36 PM
  #31
tulsa_97SR5's Avatar
bought my 85 in PA with 3" blocks in the rear and stock springs. One panic stop on the interstate on the drive home is all the personal experience I needed to know they had to go before I'd drive it again. Especially with the the suspension being older and 'broken in' the last thing you need is to add leverage to the bad forces acting on those worn springs.
Why not just do a body lift?
09-04-2015 09:27 AM
Luvmeye22re
08-04-2015 03:53 PM
makemusic116
08-02-2015 05:23 PM
makemusic116
08-02-2015 04:40 AM
coffey50
07-28-2015 10:55 AM
Quick Reply: Lifting with just blocks
