Installed new L52/ceramic clutch, problems.
I have an 81 p/u. I put in a marlin L52 5spd. and a trail gear ceramic clutch yesterday. Everything is hooked up, bled the cluch slave, but the clutch is not engaging. Without pushing down the clutch pedal i can still shift the tranny. Any ideas what it could be?
Talked to a friend of mine whos a mechanic. He said that maybe i forgot to put the 2 clips that hold the clutch fork and throwout bearing hub together on. If i did would this cause this problem?
the "adjustable " part of the slave cylinder (the pushrod) is a fairly easy piece to replicate . This is the only differance between the cylinders
the best way for an "adjustable " clutch ... which may help your problem
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
Shaun Crystal Gomban
07-30-2015 10:13 PM
