Convert FED/CANADA emissions and Vac. Lines to CALI. Config? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Pre 84 Trucks
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-05-2009, 07:41 PM   #1 (permalink)
c.updegrave's Avatar
Can I convert my 82' FED/CANADA to a CALI emissions and vacuum hose configuration? It's a total nightmare and I'd have to believe I need about 1/2 of that tangle under my hood... Can I just follow the 3D vacuum line diagrams and pull & plug lines then chuck things that serve no purpose in a California configuration?
Rebuilt/Rebushed Factory National Carb
new plugs
new plug wires
new rotor
new distrib cap
replaced most vac. lines with new ones
Truck still fast idles like crap and surges
__________________
1987 Toyota 2WD 5-Speed, 22R
1982 Toyota 2WD 4-Speed, 22R
c.updegrave is offline
Old 11-05-2009, 08:31 PM   #2 (permalink)
rowdy235's Avatar
Don't know why you'd switch TO a cali configuration if you're not in california. Cali config is much more complex and prone to problems. Your best bet to reduce lines is to do a weber carb and an EGR delete. Should clear up most (if not all) unnecessary vac lines.
PS, your 82 looks so much like mine its almost ridiculous
__________________
The Daily Driver:
1998 Tacoma | Regular Cab | 4WD | 2.7L | 5-Speed Stick | Mostly Stock
The People-Hauler
1988 Grand Wagoneer | SUV | 4WD | AMC 360 | 3-Speed Auto | All Stock
The Dump Runner
1982 Pickup | Regular Cab | 2WD | 22R | 5-Speed Stick | Custom Exhaust
FER SALE! http://www.yotatech.com/f108/1982-sh.../#post51229916
rowdy235 is online now
Old 11-06-2009, 06:58 AM   #3 (permalink)
I thought the CAL was less complicated. Take a look at both the 82' & 87' under-the-hood labels (82' is the wrinkeled one). Am I a bonehead and the CAL doesn't stand for California but something else?
I get you on the Weber, Just couldn't afford it. The rebuilt/rebushed was only $150.00...
convert-fed-canada-emissions-vac-lines-cali-config-82-toy-vac-diagram.jpg   convert-fed-canada-emissions-vac-lines-cali-config-87-toy-vac-diagram.jpg
__________________
Old 11-06-2009, 08:54 AM   #4 (permalink)
refried's Avatar
two totally different engines, one is fuel injected the other has a carb (the block is the same but intake is different).
if you take the '87 engine and put it in the '82 truck you can use the '87 emissions. to be legal in a smog tested truck the engine in the truck must be the same or newer than the body of the truck and the emissions from the newer engine used.
__________________
1981 Shortbed 4x4
Buick 231 V6, Turbo 350
4" springs
35x12.50 15 Bfg MT
300,000+ miles
refried is offline
Old 11-06-2009, 09:22 AM   #5 (permalink)
83
83's Avatar
Yes Cali model is MUCH more complex.
__________________
Zach
'83 Shortbed 4x4
L52HD
Rebuilt & Mostly Stock
83 is offline
Old 11-06-2009, 09:23 AM   #6 (permalink)
My 82' & 87' both have carburetors. The photo of the two under-the-hood labels are from both my vehicles (wrinked one is the 82'). What makes the 87' so simple?
__________________
Old 11-09-2009, 01:35 PM   #7 (permalink)
Jeff D's Avatar
I believe Toyota made carbureted 22R engines until 1995 or so, with the fuel injection option (22R-E) starting around 1985.
Maybe the California diagram is showing additional components, on top of what already exists for Federal/Canada? I didn't try to compare the two drawings side by side...
__________________
1983 2WD Longbed Pickup
Jeff D is offline
Old 11-09-2009, 02:08 PM   #8 (permalink)
I think that CAL doesn't stand for California on the 87' hood label. The carb'd 87' I have is so much simpler than my carbed 82'. Wish there was a simple way to convert the 82' into something that makes sense.
__________________
Old 11-18-2009, 10:57 PM   #9 (permalink)
the_supernerd's Avatar
CAL stands for California on the '87. I have both '87 and '88 carbureted California smog trucks and an '82 that is also California smog. The '82 has way more vacuum lines than my other trucks. It appears to be a lot more complicated than the diagram of your Federal smog '82. To simplify your '82, the conversion would have to be from '82 Federal smog to '87 California smog.
From what I can tell, California smog is more computer controlled, which might make for a few less vacuum lines depending on year. You cannot just take off parts to convert to California smog. You would have to change the wiring harness, ECU, distributor (or possibly just vacuum advance), add an O2 sensor plus the other electronic contols, and I believe the carburetors are different between Federal and California. It is doable, but probably not worth the effort. If you still want to convert it, I have a computer and wiring harness from an '86 that I will sell you.
__________________
-Anthony
1987 4x4 Carbureted 22R truck
Grill & brush guard | Roll bars | Bed liner | Tubular rear bumper | JVC CD-player | Custom 6.5" rear speaker boxes with 6.5" Sony X-Plods | Polk 3.5" speakers in dash | Fog & driving lights
Future mods:
Dynomax muffler | Spray on bed liner | Custom switch for fog & driving lights
the_supernerd is offline
Tags
cal, carburetor, diagrams, emissions, weber
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
