5.29
5.29
5.29 gears, is that about right for 38s some are saying 4.88 some say 5.13. I want to be able to drive it to where im wheeling. 5.29 with 38s they say will do about 3k at 65mph
i have 5.29's with 32's and i love them. i still can go 65mph down the road but my rpms are higher (tack's broke) but its it too high. if i was going to run 38's i would definitely go with the 5.29 gears.
also i have the 22r engine so i need all the gearing i can get.
This is about what will put you closest to stock gearing
4.56- 31" to 32"
4.88- 33" to 34"
5.29- 35" to 37"
5.71- 38" to whatever at that point you should have dual cases
A lot of guys running 38's or even 42's still like the 5.29's cause the gear teeth have so much girth. I've sheared teeth of my 4.10 ring gear before so yes this is of some importance
5.29 should be just fine for you application and for god sakes, search.
4.56- 31" to 32"
4.88- 33" to 34"
5.29- 35" to 37"
i need to re-gear my truck, i dont know if i want 4:56's or 4:88's i have a 22r with a 4 speed and 36's, i want to go as low as possible but still be able to hit 50 m.p.h. what do i need to get?
4.56- 31" to 32"
4.88- 33" to 34"
5.29- 35" to 37"
4.56- 31" to 32"
4.88- 33" to 34"
5.29- 35" to 37"
Actually if you go check out ZUK's comparison of the 5.29's and 5.71's you will learn alot about the BS behind the myth of 5.71's
check it out here
gearinstalls.com
Originally Posted by
81 169
81 169
4x4;51288169]i need to re-gear my truck, i wan know if i want 4:56's or 4:88's i have a 22r with a 4 speed and 36's, i want to go as low as possible but still be able to hit 50 m.p.h. what do i need to get?
Originally Posted by flatI have h91669
Iave h heard that some housing shaving is required for the 5.29 in a 8inch is this true. Thanks?
THough it does not pop right out like a 4.10 does I see no reason whatsoever to shave any thing off the housing...though if you did it would just need to come off slightly at the notch at the bottom of the housing...
Zuk's site does have that excellent article about the myth of 5.29's vs 5.71's as oleharleyman said.
You a manual or Automatic? Tippy is/was an automatic with 35's and 5.71's and she needed that gearing because she has such a tall overdrive. the 5.71's almost made her like a crawler. But the lack of power in the 3.slow is what would kill that crawler effectiveness. Now if I ever hook up that 3.4... WHEEEE!
FS[SouthCent]: Toyota Trail Gear 5.29 Ring and pinion x2 NEW
YotaLogic
12
11-17-2015 06:27 AM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
justdifferentials
09-05-2015 06:52 PM
coffey50
07-28-2015 10:55 AM
