FS[MidAtl]: 3rd gen 4runner Lift - Toyotec, LC 7 Wraps, Bilstein 5100's
Full setup.
Front: Bilestin 5100 front shocks, Toyotec 1 inch strut spacers. Front struts already set up. 1 inch front lift
Rear: Skyjacker M9555 shocks and LandCruiser 7 wrap coils. 2-3 inch rear lift, will fix sag and ride level with 1 inch front lift
Kit was pulled from a wreck. I was going to use this set on my daily driver but I decided to install air load bags.
$250 obo in Lynchburg VA. Local pickup only at this time. Photos are of the front setup and the difference between stock rear springs and LandCruiser springs. One rear shock needs a new $6 poly bushing.
OPEN TO TRADES - especially on FJ40 parts or firearms!
Front shock part number: F4-BE5-D558-T0
Front Spring coil paint codes: Green and Pink, Brown and White
1 inch Toyotec top spacers installed.
Rear shock part number: M9555CS
Rear Spring - no color codes visible. Length on both are right at 20.5 inches uncompressed. Rear coil springs have 7 wraps not counting the two base coils - which is as I understand it how you count coil wraps.
This entire set was removed from a 1998 that had a bag deployment from hitting tree/pole on the front bumper. No damage to the frame or suspension. It hit just hard enough to deploy and poke something into the radiator.
06-01-2021 01:51 PM
tpd143
07-07-2015 09:06 AM
