Homemade headlight wiring harness
Old Sep 28, 2006 | 01:54 PM
gregbreakseverything's Avatar
Some people have been asking questions about my wiring harness, so here are a few wiring diagrams. The relays and light connectors may be wrong, but these diagrams should give anyone a pretty good idea.
This is the basic wiring harness you can buy.
All the parts were really cheap, and I had the wire just sitting around.
Greg
Last edited by gregbreakseverything; Oct 1, 2006 at 06:49 AM. Reason: removed second picture
Old Sep 28, 2006 | 02:33 PM
MNBOY's Avatar
Probably be helpful to tell people what size wire you used.
Old Sep 28, 2006 | 03:23 PM
size 16 should cut it
Old Sep 30, 2006 | 09:14 PM
KyleT's Avatar
just a question, but doesnt running both filaments on a single bulb significantly reduce its life? like an H4? i can see the advantage on a dual bulb setup like the new 4runners and tacos.
Old Oct 1, 2006 | 06:48 AM
I would never do the dual bulb setup because I think the lights would burn out the first time the high beams are used. Someone just asked how I would do it. I will just remove the picture.
Old Oct 3, 2006 | 09:44 PM
arjan's Avatar
Does your high beam indicator work inside the cab? According to Roger Browns website it won't, which make sense after looking in my haynes manual headlight diagram.
It might work if the coil of the relay lets enough current through to light up the blue indicator.
Old Oct 3, 2006 | 09:46 PM
Keggo's Avatar
I used 14 and 12 gauge wire for my Bi-xenon retrofit...
Old Oct 4, 2006 | 06:16 AM
Everything works like stock, except the day time running lights are the same as the low beams now.
Old Oct 4, 2006 | 06:50 AM
arjan's Avatar
Thanks, I've had the relays etc laying around for months, just never get around to doing it. My DRL resister pack has been gone for years...
In Sask DRL is a good idea though. I drove 2 months ago from Calgary -> Lloydminster -> Rosetown -> Medicine Hat and back to Calgary.
Anything that makes a vehicle stand out is a good idea over there.
80Truck
Oct 12, 2025 07:25 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
TDonkey
Jul 26, 2015 10:14 AM
toofly1999
Jul 25, 2015 07:09 PM
msane99
Jul 17, 2015 10:13 AM
