1980 toyota pickup $500 obo (chesterfield, MI)
Old Sep 3, 2007 | 12:37 PM
guardsman's Avatar
1980 toyota pickup $500 obo (chesterfield, MI) ***sold***
1980 toyota pickup
1983 22R carb'd engine
L-52 5 speed manual transmission
4.37 gearing
Recently I swapped in the engine and trans. Replaced a broken rear leaf spring, replaced the radiator, hoses, clutch, timing set (single row) and all of the gaskets in the front of the engine as well as the valve cover gasket and oil pan gasket. I replaced all of the vacuum tubing and ditched the emissions stuff. The wiring needs to be cleaned up, a lot of it is held together with twist lugs. This was done while I was swapping in the engine and figuring out the wiring. Right now the truck will run and drive but it will not idle. As soon as you push in the clutch while driving it dies, it will not sustain an idle while sitting either. It is also tracking poorly, the knuckles need to be rebuilt and it will need an alignment and the track bar re-installed with new hardware and bushings if you so choose. The floorpans are also in need of attention (they are rotten) and there is a lot of misc. rust throughout but the frame is solid. All of the glass is in tact and it has a clear title. The truck is sitting on 31-10.5-15 dunlop mud rovers with maybe 30% tread and minor weather checking. The spare is in better shape with closer to 60%.
If I get my asking price I will include an extra top-shift transfer case, everything needed to convert the truck to power steering and the knuckle service kit, brand new from marlin crawler. I think there may be more but I can't really think right now.
Please feel free to make an offer, I need this truck gone by the 14th of this month. Also feel free to make an offer on the power steering stuff or transfer case if you are interested in those.
I'm sorry I can't give it away but I have a couple hundred dollars into this truck in just the last two months and I can't take that huge of a loss.
Pictures can be seen here
Old Sep 3, 2007 | 12:47 PM
HAVOC's Avatar
as always, pics?
Old Sep 3, 2007 | 01:16 PM
guardsman's Avatar
Added link to pictures in the top post.
Old Sep 4, 2007 | 04:22 PM
guardsman's Avatar
Sold.
6th Gear
19
Dec 10, 2019 07:31 AM
Weidle
Jan 21, 2019 05:39 AM
Aleeex_u
Jun 5, 2016 06:52 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
