Lots of parts + PO 87 runner
Old Apr 4, 2006 | 08:37 AM
SlightlyModified's Avatar
I've got a fresh 80-84 22r block, with some surface rust (had been blasted). a fresh 22r head w/o valves, A remanufactured crank (rust),Several used heads, cranks, cams, distributors, timing covers, stock gears, diffs, Solid front axle and rear axle housings (can be complete except short side shaft), 2 early 4speed 4x4 trans, 1 trans case. 3' BL, 2 inch blocks, etc. etc. etc....................
Also parting out my 87 4-runner 22re.
Cracked block, less than 20 hrs. on new timing set, and a milled 20r head. Keeping the headers, rear springs, ifs steering box, power steering, rear axle, front shaft.
$ make offer.
Will definetely do trading. Looking for 5.29's lockers, dual case adapters, beadlocks, 35's, bucket seats, Cross-over stearing, mig welder, tube bender. Also have clean 74 original vw bug to trade on.
Old Apr 4, 2006 | 08:39 AM
FilthyRich's Avatar
what year solid axle?
How much?
condition/
Old Apr 4, 2006 | 11:31 AM
not sure, give me somethings to look for, and I can check.
Old Apr 4, 2006 | 11:34 AM
FilthyRich's Avatar
I need a solid axle out of an 85 or older SA toyota.
Anything broken or bent??
I am really interested in the housing.
it would have to be shipped to VA, so price is a factor.
Old Apr 4, 2006 | 07:22 PM
ToyotaGuru's Avatar
Hate to Hijack I have 4 of them in yorktown, va. No third member $100
Old Apr 6, 2006 | 08:42 AM
hilandfrog's Avatar
speedo cable?
I'm in need of a speedo cable??
VR
Repo
Old Apr 9, 2006 | 11:44 AM
Yes the axle is an 85 or older, it's straight, was going to use it for an sas. I have a speedo cable from an 87 4-runner, make offer,$5 shipping.
Looking for 5.29's "quick"
Old Apr 10, 2006 | 11:47 AM
Mudlover's Avatar
Looking for a drivers side window w/o wind wing. Do you have one?
Old Apr 11, 2006 | 08:33 AM
my 87 has a wing, and I have the door glass. if you want it, make offer.
Old Apr 11, 2006 | 09:02 AM
Mudlover's Avatar
If your door has the wind wing, I can not use it. I need the full window. Thanks.
Old Apr 18, 2006 | 03:13 AM
I'm getting redy to send the runner to the scrap yard, it has many of good parts left. Make any offer for parts.
Old Apr 18, 2006 | 03:58 AM
Mudlover's Avatar
I am looking for a few things.
Speedo gauge cluster with with tach, speedo cable, and a bracket to hold up the end of the exhaust pipe. PM me if you have any of these.
Thanks.
Old Apr 18, 2006 | 08:52 AM
I have the cluster (I'll check but almost sure it has the tach) Have speedo cable, not sure what bracket you need. I have a custom exhaust on the truck.
Also, I will be at werock in columbus in may if anyone wants any parts.
Old Apr 18, 2006 | 09:37 AM
Wile E. Toyote's Avatar
I need a catalytic converter if you've got one from the '87
Old Apr 19, 2006 | 08:30 AM
yes I have the cat. pm me if you want it.
Old Apr 19, 2006 | 08:32 AM
oh, and by the way I'm not sending it to the scrap yard yet. I'm gonna hold off as long as the law will let me. It's in my driveway, on a trailer, and they said they would give me a lil longer before they write me a ticket.
Old Apr 21, 2006 | 11:23 AM
Anybody???
Old Apr 23, 2006 | 03:17 PM
Rather Diesel's Avatar
I need all four brake backing plates (in good shape). Mine has 10" drums in the back. I'm not sure what year they went to these from the 8". It's an '89 Runner.
I need a transfer case mount also.
Roy
Old Apr 24, 2006 | 03:09 AM
Sorry I'm keeping the brakes, and the transfer case mount isn't in the best of shape, not worth the time to remove. Sorry.
Old Apr 28, 2006 | 08:26 AM
OK, I torched the rear end and some other parts out last night, this truck goes to the scrap yard monday. I sold a few parts from it. I need to move it to make room for an 86 PU I just bought. Easily pulled parts are FREE!!!! If I can pull them in less than 5 min. you pay shipping and the part is free if I've got it.
