Step drill bits - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Tool Time
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-25-2008, 09:41 AM   #1 (permalink)
Co-Founder/Administrator
Staff
Corey's Avatar
Step drill bits
I need to enlarge the 3/8" hole on my ARB bumper to 1/2".
The ARBs are drilled to accept a CB antenna mounting stud.
Ham radio antennas use 1/2" studs, at least the mount I am getting for my antenna does.
Here are two step drill packages.
One is $60, the other is $10.
Do you get what you pay for, or since this will not be used very often, is it a good choice to take a chance on the cheaper one?
$60 one from my local Lowe's
$10 one from Harbor Freight, which is also local to me
Corey is offline
Old 10-25-2008, 09:52 AM   #2 (permalink)
tc
tc's Avatar
A step drill bit is the ONLY way to drill sheet/plate! You will definitely find use for it once you have one!
I think those Irwin ones will require a 1/2" chuck for the larger sizes - your drill is probably 3/8".
To be honest, I would go with the HF ones. If they burn up, go buy another set! Being that they are TiN coated, they'll probably last long enough to where you wouldn't be buying six sets over your lifetime.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 10-25-2008, 10:11 AM   #3 (permalink)
wino$41's Avatar
Ditto that. I've used this (the one from harbor freight) on my TJM bumper no problem. Once you use it though you'll find all types of things to use it on.
__________________
96 4runner, V6 SR5, Rubicon rock sliders, SS 1.1 lift, SS bumper, TJM front bumper, Hella lights, CBI tire carrier, 285/75/16 Nitto Terra Grappler, coco mats, katzkin interior.
wino$41 is offline
Old 10-25-2008, 10:14 AM   #4 (permalink)
Staff
Corey's Avatar
Thanks guys, mine is 1/2" too.
http://www.yotatech.com/50364681-post42.html
Guess I will call them up to see their hours.
They are on the same street I live on, just 12 miles or so North of me.
Corey is offline
Old 10-25-2008, 10:21 AM   #5 (permalink)
Send a message via AIM to akaphilly
i've been usin my harbor freight step drills for over a year. definatly worth it
__________________
http://cardomain.com/ride/2526416 84 p/u, 94 22re, header, RUF's f150 rears, all-pro triple x member, duals, e-locker, lsd front 35mtr
96 limited 4runner, trd s/c exhaust trans cooler, toytec coilovers, fj80 rears, budbuild front skid 285/75 procomp mt
akaphilly is offline
Old 10-25-2008, 12:08 PM   #6 (permalink)
Staff
Yoda's Avatar
We use the Irwin ones at work.
I have a set I could have loaned you today when I went for my strike check. I also have a 1/2" drill if you would rather use that.
But for $10 the HF set should be fine.
__________________
David
TLCA 14788
71 Landcruiser FJ-40 TBI 327, TH-350, Warn 8000, disk axle swap.
76 Landcruiser FJ-40 project/parts (haven't decided)
Yoda is offline
Old 10-25-2008, 12:13 PM   #7 (permalink)
yotasavg's Avatar
i have the HF ones. had em about a year, i find uses for them too.
__________________
-Andrew
94 4Runner 3.0 Auto.
I got mods
Now Back in Action!
yotasavg is offline
Old 10-25-2008, 12:20 PM   #8 (permalink)
olharleyman's Avatar
I can loan you one if you want to wait a week for shipping lol but really like everyone else said $10 you will more then get your moneys worth I have the IRWIN set and use the hello of of them fabrcating on motorcycles and they work great just remember to start a small piolot hole so you don't burn the tip up on them.
__________________
1990 4 runner 5 Speed
Pro Comp Stage II 4" Lift 6" coils rear
Aussie Locker front
5.29's Front And Rear
35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels
Super Charged 3.4 on the way
1993 SAS 4runner 22re 5 speed
4" front 5"rear
5.29's
35 x 12.5 BFG KM'S
Dick cepek DC 1's
88 stock 4runner
3.0 auto
for now
1955 Harley Davidson Springer
Stock 1955 Hardtail Frame
4 Speed
Kick Start Only
1998 Harley Custom Dresser
107 rwhp
139 ft.lbs.trq.
olharleyman is offline
Old 10-25-2008, 12:24 PM   #9 (permalink)
Staff
Corey's Avatar
Thanks guys, I am going to hit HF tomorrow morning and get the $10 set.
That is $50 more I can put towards my Yaesu 857D
Corey is offline
Old 10-25-2008, 03:52 PM   #10 (permalink)
The cheaper ones will dull the center part much faster, I find with my cheap one I have to get the hole started with a small bit and then I can use my step drill to make a larger and cleaner hole
schmooot is offline
Old 10-25-2008, 03:56 PM   #11 (permalink)
Staff
Corey's Avatar
I will see how long the HF ones last.
But I already have the stock hole in the ARB bumper, just need to enlarge it.
I think the reason ham antennas use a larger hole for the base is so the mounts can hold a much larger antenna than a CB one.
My future antenna after I try out the one that is on order now.
Asat-120 by Yaesu.
Corey is offline
Old 10-27-2008, 10:32 AM   #12 (permalink)
TC4RNR's Avatar
Harbor Freight all the way. i've used them so so many times no problem at all. get a center punch and good 1/4" drill bit if you need drill a new hole, the step drill isn't good for drill polit holes no matter who makes it.
__________________
http://i172.photobucket.com/albums/w...gca/agreed.jpg
94 4Runner, SR5 3.0V6, 4WD, 5spd: SOLD
99 4Runner, SR5, 3.4L 4WD, 5spd. LC80 wheels, SS 1.2 lift, Marlin 1200 Clutch, ARB front bumper, BruceTS rear bumper, roof busket, hitch mount tire carrier, Tundra Brakes, Brembo rotors, BudBuilt skid, Lightforce 240 Blitz, PiAA HID, Stubb's HD-SKO sliders. ScanGauge II
04 4Runner SR5 V6 4WD. 265/75/16 BFG KO, FJC coils and silver Bilstein shocks, Scion H/U.
TC4RNR is offline
Old 10-27-2008, 10:34 AM   #13 (permalink)
Staff
Corey's Avatar
Just got back, picked up the Harbor Freight ones, they look to be pretty good quality for less than $10.
She was surprised to see me in and out of the store in under two minutes.
Most spend a long time gawking up and down the isles, but not me today.
I really did not have anything else to look at while I was there.
Corey is offline
Old 10-27-2008, 01:33 PM   #14 (permalink)
Staff
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
Looks like you already made you purchase...but I would have suggested the Irwin bits. Last a lot longer, and higher quality. I bought 2 when there were buy one get one free at my local lowes. $50 or so.
__________________
Tacoma miniheader install kit Now available! Click here for ordering information
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by space-junk View Post
DeathCougar, you know everything!
Quote:
Originally Posted by fustercluck View Post
Now I know DC is a leader.
DeathCougar is offline
Old 10-27-2008, 01:42 PM   #15 (permalink)
ocdropzone's Avatar
I bought two sets when I was there just in case.
Corey are you feeling OK? Nothing else to look at while you were there? You should go see a clinic
My wife hates it that there is a HF store 3 miles away from me
__________________
~Robb
'81 Trekker The B4Runner Build
TREKKER Forum
Mini FAQ/Misc Ideas Thread
**TRY THESE SEARCH LINKS**
GOOGLE FOR TOYOTA WEBSITES
LINK TO ONLINE FACTORY SERVICE MANUALS
Drive a real 1st Gen
Wheel Responsibly, Don't Screw It Up for Others
ocdropzone is offline
Old 10-27-2008, 01:55 PM   #16 (permalink)
Staff
Corey's Avatar
'Coug, I will see how these last, I may get the Lowe's later.
Robb, I did not want to cloud my mind with more purchases
Soon I will be dropping a load on a new LCD TV, and also a load on HAM gear for the rig.
Corey is offline
Old 10-27-2008, 03:28 PM   #17 (permalink)
Staff
aviator's Avatar
Can't comment on HF never seen them but I've used the Greenlee step bits and they are the shiznit... just be careful they can grab and either torque your wrist off or chew up the finish on what you're working on. Use a little cutting oil and it should go nicely and help keep a good edge on the bit longer. Motor oil also works if you don't have cutting oil handy. Also they can "take off" all of a sudden and you wind up with a bigger hole then you had in mind so be careful of that too.
__________________
Silver 1994 Hilux Xtra cab 4x4 3.0
K&N cone filter, ported MAF, advanced timing, oversize exhaust, free flow cat, "rumble" muffler
custom covered SR5 seats, map lights, factory AC
tv4184 style black interior conversion started
mods to come... header,
custom centre console, stereo upgrade
tinted windows
Founding member 1972TLC fan club - Get well soon Mary
Toyota Hilux... Get in or Get out of the way.
aviator is offline
Old 10-27-2008, 03:43 PM   #18 (permalink)
ocdropzone's Avatar
Corey- We are thinking too about an LCD for the family X-mas gift...Ham gear would be cool...What kind? I would love to get one but I am thinking about one of the SPOT emergency locators if this quarter's bonus is big enough after taxes would be better for me (hiking etc), already blew part of it on a 15lb Ultimate Air set up
__________________
~Robb
TREKKER Forum
Old 10-27-2008, 03:49 PM   #19 (permalink)
Staff
Corey's Avatar
I have a ham thread here.
http://www.yotatech.com/f97/two-meter-ham-155889/
I have changed my mind quite a bit on the gear.
So far I have a Diamond antenna for 2 m and 70 cm work coming this week along with the coax and ARB bumper mount.
But down the road I am looking at the ASAT-120A antenna which is made for the Yaesu 857D radio I will get when the strike is over.
Gotta get a duplexer for the antenna too, since one antenna will hook up to the two ports on the radio.
Corey is offline
Old 10-29-2008, 12:46 PM   #20 (permalink)
Staff
Corey's Avatar
The drills worked like a charm.
In fact it was like drilling into butter
http://www.yotatech.com/f97/two-mete...l#post50957696
Corey is offline
Tags
38, antenna, bit, bits, cobalt, diamond, drill, drills, freight, harbor, harborfreight, hook, mount, step, washington
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Finally! Painted the toyota. Step by step pics. 56K no no. MIKEMOKAS 86-95 Trucks & 4Runners 54 10-18-2008 09:05 AM
Step by step: Replacing radiator on 3rd gen p/u Jay351 Maintenance & Repair 0 07-30-2008 02:00 AM
COBALT vs HSS Drill Bits rngrchad Tool Time 5 08-31-2006 10:02 AM
Step by step intructions for retro-fitting 99-02 front bumper on 96-98 4Runner? Jason B 95.5-2004 Tacomas & 96-2002 4Runners 4 08-31-2004 09:11 PM
To drill or not to drill throught the firewall??? impulsebrklyn 95.5-2004 Tacomas & 96-2002 4Runners 18 03-12-2003 02:01 PM
2009 InternetBrands, Inc.
